Introduction: Modular Wiring Installation
Step-by-step instructions on how to install modular wiring to Panel Built's binder post system.
Step 1: Install Junction Box Into the Binder Post
Place two pieces of cardboard between the junction box and the sides of the binder post.
Use two screws to fasten the back side of the junction box to the binder post.
Step 2: Add Modular Wiring to the Junction Box
Insert the modular wire through the bottom end of the junction box, while aligning the remaining cord through the top of the channel.
Step 3: Use One Hole Straps to Fasten Wiring
Screw 2 one hole straps to the binder post. One strap being 8 inches from the top of the junction box, and another strap being 8 inches from the top of the binder post.
Afterward, add your top piece of snap to the binder post.
Step 4: Connect Actual Wires to the Receptacle
Strip and curl the actual wiring.
Connect the exposed wires to the receptacle
Black wire to bronze screw
White wire to silver screw
Green wire to green screw
Tighten the screws on the wires when finished
Step 5: Wrap the Receptacle With Electrical Tape
Step 6: Screw the Recptacle to the Junction Box
Step 7: Finally, Add the Duplex Cover Over the Receptacle
Screw duplex cover to the Receptacle.
