Introduction: Moire Effect Spinning Lamp
I had originally wanted to make myself a spinning picture lamp. Though I realized that these lamps use the heat from incandescent lamps to cause them to spin. I wasn't really thrilled about the idea of using incandescent bulbs and I no longer had any of them around. I did however have a computer fan with LEDs.
The fan, unfortunately, spins much to quickly to be used for pictures. I tried using with patterns of strips and spirals and discovered that it created an interesting Moiré effect. Hence the name, though I was also considering calling it the "Hypno Lamp".
The lamp consists of two cylinders the pattern on the outside cylinder is printed on a transparency sheet and the spinning cylinder on the inside is printed on regular white printer paper. Both of these can be switched up, so you can try out different patterns.
Step 1: What You Will Need
- PC Cooling Fan with LEDs (80mm diameter) -I bought mine here
- 1.5-12v Ac adapter ( my adapter can switch between 1.5-12 v)
- Glass vase ( mine is 6inch high and 11 inches in circumference - I bought it at a dollar store
- Transparency sheets
- Regular white printer paper
- Computer and colour printer
- Scissors
- Clear tape
- Pliers to strip ends of wires
- 2 twist on wire connectors
- Optional -Sugru
Step 2: Print
For the lamp I needed to print out a pattern on transparency sheet to fit around the outside of the glass, the dimensions required where 11x6 inches. I also needed a pattern that rotates with the fan, I printed this out on regular white printer paper that is 9.375x6 inches. (The width needs to be precise since it has to fit over the fan blades but not be too loose that it slides down.)
I tried out a few different patterns in different colours to use with my lamp with varying effect. This site gives some interactive examples on how different Moiré patterns are created. Looking at the images above you can see the Moiré effect caused by your computer screen.
Step 3: Outer Cylinder
Trim off the non printed area of the transparency sheet at the top and bottom (but leave the sides -the diameter of my vase is 11 inches but I couldn't convince my printer to print beyond the margins so there is a bit of a gap.) Tape the ends together forming a cylinder with clear tape. This should fit snugly around the glass, but you can still slide it on and off.
Step 4: Inner Cylinder
Trim off the non printed area . Put tape along the bottom edge of the rectangle, this is to prevent it from tearing as you place it over the fan blades. Tape the ends together forming a cylinder with clear tape, there should be a small 1/8th inch overlap of the edges. This should fit snugly around the blades of the fan, if it is too loose it will slide down impeding the spin of the blades. It is a bit tricky getting it over the blades, you may need to worry them over, especially the last blade, since it is a tight fit.
Step 5: Power Source
The computer fan runs at 12v and has a 3 pin connector. I have an AC adapter that has an adjustable voltage between 1.5v and 12v, this is great since I can reduce the voltage and slow down the spin of the fan (unfortunately though, it also dims the LEDS). I remove the connectors from both the adapter and fan cables (mark which wires are positive and which are negative/ground first), then connect them using two of those twist-on wire connector caps.
Step 6: Bumpers
To ensure the glass vase stays centred on the fan I screwed the screws that came with the fan onto the corners. I then covered them with Sugru, to form bumpers.
