Introduction: Momentary Contact Switch
I need a dependable momentary contact switch for a low voltage circuit, but I want to spend very little money on it. I made a momentary contact switch that can be adapted for a variety of configurations. Shown is a very basic form for demonstration purposes. A key part of it is a non-conducting spring made from a piece of a common nylon cable tie.
Materials and tools are given in regular print and in italics. Those italicized concern the second part of this Instructable in which I built a momentary contact switch for a trigger mechanism on a non-contact voltage tester (NCVT).
Materials
- Nylon cable tie
- Wood block or other mounting material.
- Brass screw
- Wire
- Hot glue (optional)
- Plastic electrical tape
- 1/4 inch white plastic Plexiglas
- 12 gauge copper wire
- Brass sheet
- Solder
- Small sheetmetal screws
Tools
- Drill and drill bit (or thin saw)
- Side cutter pliers
- Knife
- Fine saw (hacksaw)
- Screwdriver
- Soldering gun or iron
- Pliers
Step 1: Prepare the Mount
Drill a hole into the mounting material (or wood) at a low angle. The diameter of the hole should be sized so the nylon cable tie fits into it fairly well, but not too loosely. A thin saw about the thickness of the cable tie could be used to make a mount for the cable tie, as well.
Step 2: Cut and Fit the Nylon Cable Tie
Cut the thin leader on the cable tie's end away and place the blunt end of the cable tie into the hole from the previous step.
Step 3: Making It Into a Switch
Wrap bare copper wire around the end of the cable tie. Use plastic electrical tape to secure the wire to the cable tie. Put on a bead of hat glue if there is a need to insulate the conductor electrically. Drill a hole into the mounting material for the brass screw and insert the screw. Make a loop on the end of the other wire after stripping the insulation from it and tighten the brass screw to hold the wire. The nylon cable tie insulates and provides a spring that returns to its original position when released.The bare end of the wire wrapped around the end of the cable tie could be tinned with solder for more permanence. Be careful not to damage the nylon cable tie with too much heat.
Step 4: Background Reason for This
I have used commercially available non-contact voltage testers (NCVT), but I have forgotten how much time had passed since changing the batteries. The batteries in them leaked and ruined the testers. So, I built two of the circuits at this Instructable. I power one of them based on a 4017 chip with two 2032 batteries. Those have never leaked for me. I powered the other with a 9 volt battery. Those batteries also have not leaked for me.
I found the battery drains a little and goes "dead" when not in use on the circuit based on a 555 timer after a couple of weeks. I added a pushbutton momentary contact switch to both circuits. See the photo for one I mounted inside a plastic pill bottle. But, I have not had good experiences with those pushbutton switches. They quickly become very rough in their action and electrical contact through the switch becomes unreliable. I wanted an alternative I can operate smoothly and reliably with a trigger mechanism, and decided to make my own. What follows adapts the basic momentary contact switch in the preceding steps of this Instructable.
Step 5: My NCVT and Trigger Switch
Someone gave me some white plastic Plexiglas 1/4 inch in thickness that I am using to make a pistol grip NCVT with a trigger switch. The photo shows cutting a piece for the trigger from a piece that will become part of the pistol grip. The table saw is my home made adaptation of a good 7 1/4 inch circular saw. I have used this table saw adaptation for many years and find it very accurate and reliable.
Step 6: Fitting the Trigger to the Pistol Grip
I have attached the pistol grip handle to the flat piece of Plexiglas on which I will mount the circuit assembly. The piece for the trigger switch has been laid in place for fitting. The top front corner of the trigger touches the circuit mount to function as a stop for the trigger on its return. The trigger is cocked so there is a gap at the top rear to provide space for it to rotate.
In the second photo I have drilled a pivot hole through the trigger and the pistol grip behind it.
In the third photo the pivot screw for the trigger has been added with a washer. Leave it just loose enough that the trigger moves smoothly. A piece of plastic has been cut to be part of the pistol grip in the same layer with the trigger. The photo was taken in the process of marking and cutting to fit around the trigger while leaving a gap for internal electrical parts, etc.
The fourth photo shows the part of the pistol grip that fits around the trigger with a nylon cable tie laid over it to decide where it should be mounted to act efficiently as a return spring for the trigger.
Step 7: Switch Internal Working
The first photo shows the trigger piece next to a piece of 12 gauge copper wire. The wire has been bent to fit into two holes in the back edge of the trigger piece. (The two holes are difficult to see because they are white on white with very little shadow.) The second photo shows the 12 gauge wire set into the holes in the trigger piece. The holes were angled to help hold the wire in place. I also soldered a connector wire to the 12 gauge wire. The connector wire passes through a hole large enough to allow free movement when the trigger is pulled. The third photo shows the internal parts of the trigger activated momentary contact switch. Toward the lower part of the photo is the spring action provided by the cable tie piece. Its upper end will extend as the trigger is pulled, so leave space for it to move. The other conductor is a piece of brass sheet that has a concave bend on each end formed into it. Thin saw cuts have been made in the plastic to receive and hold the brass strip in place. The other lead is soldered to the brass strip.
Another thickness of plastic is screwed to the handle to keep all of these pieces in place, but is easily removable in case they do not stay in place. I had to thin the backside of the plastic covering the switch internals a little to be certain the trigger does not catch or hang up from friction.
Step 8: Finished Trigger Switch
I used a piece of scrap plastic to cover the internal parts of the trigger switch, mostly to keep them from falling out. If anything goes wrong, I can remove the cover and make modifications. With an NCVT there may be concerns that a high voltage under test could somehow enter the NCVT circuitry and cause electrical shock to the user. Covering the parts with another layer of plastic provides extra protection. As mentioned in the previous step, I did thin the overlay piece of plastic a little to ensure the trigger can operate without friction from the overlay piece.
This NCVT is physically larger than most pocket commercial units, but I use it like I would a digital meter. That is I am not carrying it during the day in a shirt pocket, but reach for it like I do for larger tools. For me, its size does not matter. A smooth, dependable trigger switch action matters far more than its size.
If I were to make this again, I would make the trigger piece wider. The spring action from the cable tie is very adequate, but a second piece of cable tie layered with the first to make the trigger pull heavier would not be unwelcome and would make accidental engagement of the switch less likely. When I store this NCVT in a drawer, I am careful that nothing else can press the trigger by accident. A sufficient gap between the back of the trigger piece and the plastic layer in the handle behind it would need to be provided if an extra thickness of nylon cable tie were to be added.
Step 9: NCVT Circuit Modifications
The graphic is the schematic I am using for my NCVT based on a 555 chip. It includes some modifications I made based on experience. As mentioned I increased the battery size to 9 volts because such batteries are so available and are easily kept away from the circuitry to avoid damage in case of leaking. If you forget to check on the battery after several months, the battery will simply go dead. Even if it leaks corrosion will not reach the rest of the circuitry. The extra voltage also provides more than enough power for good sound on the buzzer. A 555 chip can work on a range of supply voltage that considerably exceeds 9 volts, so excessive voltage to the 555 timer is not a worry.
Somewhere I read it is good practice to tie pin 4 on a 555 timer to pin 8 for stability. That was not part of the circuit in the Instructable I linked. And, the original circuit linked above has a 220 Ohm resistor connected to pin 3. Then the buzzer and the LED connect to the opposite end of the resistor. The purpose of the resistor is to reduce the current going to the LED to protect it. I do not want to reduce the performance of the buzzer, so I connected the buzzer and the current control resistor directly to pin 3. The buzzer bypasses the resistor. And, I added a momentary contact switch to isolate the battery from the circuit when not in use.
In use, I find I need to wave the antenna slowly near the conductor being tested for live current. This tester may display a flash from the LED when the switch is engaged, even with a conductor that has no live current. It may even remain "on" briefly. But, the LED is steady and does not flash unless live AC current is present in the conductor under test. A lot about sensitivity depends on the antenna you use (connected to pin 2). You can experiment with the length and shape of the antenna for your best results. Most of these antennae are not longer than about six inches, but mine currently is almost double that and it works fine.
I have tried to decide if the 555 timer in this circuit is in astable mode or monostable mode. A 555 timer acts as an oscillator only in the astable mode, and this one oscillates. But, the 10K resistor and 4.7 microfarad capacitor between pins 1 and 8 with a connection to pins 6 and 7 between is typical of the monostable mode. That would be a one-shot configuration that requires resetting after each cycle. But, the sine wave of alternating current may provide the needed reset. But, AI says NCVT circuits with a 555 timer are typically in the astable mode. It does not really matter as long as the circuit works.
Step 10: An Adaptation of the Momentary Contact Switch
I am making an NCVT for a family member as a Christmas gift. I want to mount it inside a piece of 1 inch PVC. I will not go into a lot of detail or step-by-step instructions. The first photo shows the basic switch. The cable tie piece is hot glued to a notch in a piece of 3/4 inch PVC slightly reduced in diameter to fit snugly inside the 1 inch PVC tester body. A piece of brass sheet has been wrapped around the end of the cable tie piece. The contact under it is a piece of 14 gauge copper wire. The second photo shows the circuit assembled and nearly ready to insert into a piece of 1 inch PVC. The third photo shows the assembled tester. The piece of cable tie is under the tab cut into the 1 inch PVC for depressing by the operator's thumb. As you might guess there is some careful measuring and fitting to arrive at a working tester easily used by anyone. I used a heat gun and a wood form to reshape the back end of the tester to accept a 9 volt battery. A nylon screw in a threaded hole from the side keeps the battery from falling out.
