Introduction: Monitoring Temperature and Humidity Using Cayenne
In this project we will create temperature and humidity monitor using cayenne.
We can monitor anywhere in this world using internet..
Why cayenne?
Cayenne is easy to use for beginner, and powerful to expert.
Step 1: Hardware and Software
In this step we need hardware and software below :
ESP8266-12E
DHT22 Module
USB FTDI (to program ESP)
Arduino IDE and cayenne
Step 2: Circuit Diagram
The picture tell us how to make connection on the circuit
Step 3: Program ESP12E
You need to program your ESP-12E to connect to your wifi access point
change the value of ssid, pwd, and cayenne token to yours.
DHT_Cayenne
Step 4: Setup Cayenne Dashboard
The next is, set up your cayenne dashboard like on the pictures attached.
You're almost done and can monitoring temperature and humidity from anywhere!!!
7 Comments
4 years ago
Hi, you may find it in the long run better to fit a 4k7 pullup resistor to the DHT22 signal output pin. As this is needed with this sort of single wire comms system.
See the DHT11 example pictured.
Tom..
5 years ago
How to add a second same sensor
5 years ago
Are GPIO's will be the same if I would use 3 x esp8266 in one cayenne? One DHT for one ESP?
5 years ago
Is it necessarh to change something to have 3 the same modules connected to wifi and cayenne? GPIO's will be the same?
6 years ago
Step 4 is a bit brief. A bit more explanation, please.
Reply 6 years ago
- Add new
- Device/Widget
- Sensors
- Generic
- Analog input
And did'nt use subroutine in the IDE..
6 years ago
Cayenne seems like a really versatile tool. I am going to have to try it out.
