Monkey Bridge (The Real Deal)
Intro: Monkey Bridge (The Real Deal)
The well-known, time-tested, traditional Monkey Bridge is perhaps the most familiar of all Scout pioneering projects. It’s frequently featured at Scout Expos, Camporees, Scout Camps, and is often a central attraction at public gatherings where Scouting is represented.
Using a double A-frame to build a monkey bridge is a departure from the usual X-frame that supports the foot rope and hand ropes. This new method has two distinct advantages over the X- frame version.
First, the double A-frame provides a wider base making it less likely to tip over. The second advantage is that the positions of the A-frames can be adjusted so the span between the hand ropes can be narrowed for better balance as you make the crossing.
Here's a detailed, step by step procedure and list of materials.
STEP 1: Building A-Frames
Scouts lash together two 8ʼ spars and one 6ʼ spar to form four A-Frames.
STEP 2: Doubling the A-Frames
Two A-Frames are joined together to form each side of the bridge.
STEP 3: Position the A-Frames
The Double A-Frames are held up in the proper positions and at the right distance.
STEP 4: Attach Foot Rope and Hand Ropes
Two Hand Ropes and one Foot Rope are tied on and anchored at either end.
STEP 5: Attach the Spanner Ropes
Spanner Ropes are added to the Hand Ropes and Foot Ropes.
STEP 6: The Monkey Bridge Is Tested
The Monkey Bridge is tested and adjustments are made as necessary.
3 Comments
makersmakestuff 4 years ago
Larry Green 11 years ago
