Introduction: Monkey Wrench Restoration
About: Canadian Craftsman
Decided to restore an old monkey wrench. The patina looked awesome on this so I tried my best to preserve it. I think it turned out alright!
Tools:
drill press
belt sander
file
wire wheel
vice
dremel with a scotch brite wheel
Material:
wood for handle
epoxy
Birchwood Casey gun blue
boiled linseed oil
paper towel
Evaporust
Step 1: Disassembly
Simple disassembly. The wrench is held together with a nut on the bottom. In this case I had to sand down the end of the wrench to remove the ceased nut.
Step 2: CLEAN PARTS
  • Place parts into a tub of Evaporust. Leave in for 24 hours.
  • Remove and wipe clean with paper towel.
  • Any remaining rust removed with a wire wheel.
Step 3: Restore Wrench Surfaces
  • Use a belt sander to clean up the wrench. Remove any mushrooming and larger dings.
  • File the work surface of the wrench jaws flat.
Step 4: Bluing Surfaces
  • Using a scotch brite wheel on a dremel, brush the entire surface of the wrench. This helps bluing to have a nice consistent finish.
  • Wipe wrench parts with acetone.
  • Apply bluing all over.
  • Rinse parts with water.
  • Now to seal the bluing, apply oil to the wrench and let it sit for a few hours.
  • Wipe clean.
Step 5: Make Wooded Handle
  • Select a piece of wood and cut to length with a mitre saw.
  • Drill hole through the wood.
  • Cut chamfers on all corners of the wood with a table saw. This removes most of the material making it easier to round edges later.
  • Remove more material (round the edges) with a belt sander.
  • I used my drill press as a make shift lathe and mounted the wooden handle into it. I then completed the final shaping/sanding in this step. See video for more clarity.
Step 6: Assembly
  • Use epoxy to adhere wooden handle. Let the epoxy cure for 24 hours.
  • Wipe boiled linseed oil onto the handle and wipe clean.
Thank you for following along!
