Introduction: Monkey's Fist
This is a good defense weapon and a cool looking knot for your keys and other items
Step 1: Materials
Materials you will need to make the monkeys fist are:
- 50 inches of para cord
- marble
Step 2:
You will need to cut 50 inches of para chord and then burn the ends so that the para chord doesn't fall apart.
Step 3:
You will need to hold the marble between your index and you thumb and then wrap the para chord four times around your two finders.
Step 4:
Next you will need to pass the para chord under your index finger and wrap it four times around the para chord. Once you've done that you can slide it off if your para chord is rigid enough.
Step 5:
You will need to pass the para chord through he bottom hole and wrap the para chord around the middle four times.
Step 6:
You will now need to tighten the para chord. This is the longest process but it gives a good result.
Step 7:
The monkey's fist is now done but you can add a noose so that it can become a key chain. You will first need to make a loop and then another in the other direction. Then you will need to wrap the para chord around the second loop.
Step 8:
You will need to finish warping the second loop completely and then leave about a centimeter and put it in the loop. Then you will need to tighten the loop by puling on the noose.
Step 9:
You can add this on your keys, knives, or even just just make it a key chain.
Step 10:
I'm not sure if I was clear enough in explaining the steps, but I think the photos will help. Also if you have any questions please don't hesitate to ask. Suggestions and corrections are appreciated. I hope you enjoyed making this monkey's fist.
