Introduction: Monochrome Orange Necklace
Orange, Dark Orange, Orange Red...
This color has many endings and uses.
We love Orange for the liveliness of its color and it has been proven that the color orange is the one that stands out best in many environments, so used:
- Road hazard signs, warning lights and in the two traffic lights
- Sports (Apprenticeship grade in some martial arts and team representative color)
- Political symbol by some countries
- Commercial uses
- Cultural uses (example: architecture of the San Francisco bridge, the famous "Golden Gate Bridge" painted in Orange International
- Prisoners in the US penitentiary system and those at Guantánamo wear orange uniforms,
- The flight recorders, known as black boxes because the crew does not have access to their content, are painted orange to make it easier to find them if the plane is destroyed.
- Nature (fruit, flower, sunset, leaf, insect, ochre, animals ...)
Orange is a chromatic field of bright colors which, on the chromatic circle, take place between red and yellow, as in the rainbow.
In color theory, orange has a strong positive, even optimistic value. It is a living color that inspires good humor, dynamism, warmth. The orange color is associated with movement, it is present for example in the movement of flames.
We also find the ORANGE color in Fashion, as with certain accessories.
Here is my realization of a Totally Monochrome Orange Necklace to participate in this contest.
- 2 Pliers https://amzn.to/44dw1K2
- Scissors https://amzn.to/3pxoIh0
- Nylon to sew the fibers 0,10 https://amzn.to/3JDY8d6
- Pearl sewing needles, Nb 10/13. https://amzn.to/3JFq4gw
- Multi-porpose glue https://amzn.to/46CtxGH
- Lighter https://amzn.to/3PE7k4X
- Soutache cords in nylon 3mm (4 different colors Orange shades: Orange, Tangerine, Apricot, Metallic Carott) https://amzn.to/3pBS4ef
- 1 Golden clasp hypoallergenic stainless steel https://amzn.to/3CWKWwb
- 4 Golden double rings hypoallergenic stainless steel https://amzn.to/43aHicD
- 2 Orange faceted glass drops https://amzn.to/44z3hv3
- 1 Orange Coral faceted glass drop https://amzn.to/44z3hv3
- 1 Dark Orange Oval Glass Rhinestone https://amzn.to/3rdU4Ka
- 2 Round Light Orange faceted glass beads https://amzn.to/3CZXvGW
- 2 Round Dark Orange faceted glass beads https://amzn.to/3ricSI0
- 2 Orange tinted square agate stones https://amzn.to/44dHlFS
- 2 Orange smooth round beads https://amzn.to/3NGQYps
- Seed beads in 4 different shades of Orange https://amzn.to/43a85WC
- Orange Crystal cubic beads https://amzn.to/3PEoXSb
- Small orange tube beads https://amzn.to/448EWfF
- Dark Orange Leather https://amzn.to/3NZ25LR
Step 1: Sketch & Orange Colors
Make the sketch of your jewel.
Select 4 shades of ORANGE colors from the soutache cords. Then, all the beads stated in the list of materials above.
Step 2: Realization of the Central Piece (N°1)
Sew on the coral colored oval crystal rhinestone using 3 different orange colored soutache cords (Orange, Apricot, Metallic Carrot) .
Make 2 bundles of 3 soutache cords on each side. Sew them together using the fine needle and transparent nylon thread. Place a small drop of glue on each edge of the crystal to fix the soutache cords.
Put a clamp on each side for 5 minutes. When it is glued, sew an orange bead in each corner (x4).
Step 3: Next Parts (N°2)
Sew 2 cords of soutache (Orange & Tangerine) around a large round faceted orange crystal bead.
Then insert a slightly smaller round orange bead. Cut the soutache cords and burn the tips with the lighter to prevent the string from fraying.
Take 2 cords of soutache (Orange & Apricot) to fix on one side: small orange tube beads and on the other half small orange seed beads.
Step 4: Before Last Piece (N°3)
Sew 3 soutache cords (Orange, Apricot & Metallic Carrot) around a Dark Orange faceted round crystal bead. Stir in a smaller round Orange bead (like the one from the previous step).
Go around the back to sew small Orange tube beads up to halfway. Then, sew an Orange flat round bead to the end.
Step 5: Symmetry
Repeat parts 2 & 3 a second time to obtain the symmetry of the necklace.
Place the Orange crystal drops to get a better view of your jewel.
Step 6: The Choker
Make the 2 symmetrical parts of the choker. Each side should measure approximately 28 cm each.
Take 60 cm of soutache cords (Orange & Apricot), fold them in 2 and slide a double steel ring and a lobster claw on one side and 3 double rings on the other side.
Sew the soutache cords by spacing between a small Orange seed bead and a sewing stitch (x6).
Step 7: Embedding Dyed Orange Agate Stones
Sew a final Orange crystal cubic bead before incorporating a tinted Orange Agate Stone.
Sew the 2 soutache cords on each side of the stone, giving it a square shape, then stick them on the stone. Unify the 4 soutache cords with the needle and attach a small Orange seed bead to each end of the square bead.
Sew small Orange tube beads along one side of the square agate stone, ending with a square Orange crystal bead. And on the other side, sew on an Orange round bead and a seed bead.
Perform the same process on the other side, reversing the direction of the beads to obtain symmetry.
Step 8: Assembly of All Parts
Assemble all the pieces and give them the right inclination so that the necklace perfectly fits the shape of the neck. Sew each piece with the needle one by one.
Step 9: Add Orange Drops
Sew the orange crystal drops.
- 1 faceted Coral color drop on the central part N°1 (with 3 small Orange seed beads and 1 cubic Orange crystal bead)
- 1 faceted Orange drop on each side of part N°2 (with 3 small Orange seed beads)
Step 10: Leather Finishes
Trace the outline of each piece on the dark Orange leather sheet. Cut and glue each piece.
Step 11: Final Result
ORANGE: A flamboyant color to best represent a monochromatic look like a Sunset. Here is a piece of jewelry that will be fun to wear and that will illuminate any other complementary color.
You can discover this necklace, made for this contest on my shop: www.etsy.com/fr/listing/1503019636/collier-orange-femme-en-cristal-et
Thank you very much for viewing this contest. I'm counting on you for a little like if you enjoyed.
