Introduction: Monster-Light
Modify a Bluetooth Path Light to Create a Monster-Light
Step 1: Items Used in This Project
- Bluetooth Path Light Low Voltage- Source Home Depot
- Transformer Low Voltage-Home Depot
- Soldering Iron
- Solder
- Zip ties
- Scissors
- Laminating Machine
- Clear Tape
- Electrical Tape
- Sheet Protector
- Cardboard- about size of a paper sheet
- Wire Stripper- Source Amazon
- Flat Bar of Aluminum- Source Home Depot
- 1/2" X 8" PVC Riser- Source Home Depot
- Speaker Wire- Source Radio Shack
- EMT Pull Elbow Inside Corner 3/4"- Source Home Depot
- EMT Set Screw Coupler 3/4" Steel- Source Home Depot
- Pencil
- Dremel with accessories
- Glue-Source Walmart
- Exacto Knife
- Hookup wire-Source Radio Shack
- Monster Printout and eye
Step 2: Get Your One-Eyed Monster
- Print the images or you can also get any other one eyed monsters you desire.
- Print out the Monster you chose with the corresponding eye.
- Cut out your monster so only your monster is visible
- Set your monster cutout aside
- Get your Bluetooth Path light and start taking off the big 3 screws.
- Prep your Soldering Iron
- Locate the speakers on the top part of the light and remove all the screws.
- Your speaker wires should be exposed, using your soldering iron remove the wires from the speakers
- Remove the white dome from the Path light
Notes- Save your screws
Step 3: Skills With Scissors and Tape
- Grab the white dome and your monster print out
- Center and Align the dome on your monster and with a pencil trace out a circle
- Cut out the circle with some scissors
- Grab your eyeball and cut out the Iris only
- Use clear tape to laminate it
- Cut out any excess tape
- Using some Zip ties reassemble the base and the first tier piece with the white dome
- With some glue adhere the eyeball to the white dome
- Let it dry
- Grab your monster print and laminate it( just for waterproofing)-
- Substitute this step with clear tape or sheet protector if you do not own a lamination machine
- Cut out excess material
Step 4: Create Carboard Backing and Attach to Path Light
- With a pencil and your monster, trace out your monster onto the cardboard.
- Cut off the arm and legs of your monster on the cardboard
- Take off 1/8" border so the cardboard does not show around the edges of your monster
- With a sheet protector and tape cover the cardboard cutout to protect it from water.
- Align cardboard with Bluetooth path light and mark three holes
- Using zip ties secure the cardboard to the Bluetooth path light
- Grab your monster cutout and turn it over and place tape(can use double stick tape instead)
- Place tape all around main body
- Align and attach monster cutout to the cardboard
Step 5: Reattaching the Speakers
- To reattach the speakers for the Bluetooth Path light we need to extend the wires
- Cut two pieces of hookup wire about 4",
- Strip the ends off
- Solder to wire coming from Bluetooth Path light
- Use electrical tape
- Taking note of the negative/positive wire from the Bluetooth Path light route the wire into the top cover where the speaker goes. Negative wire has white dashed lines on it
- Solder the negative to negative terminal and positive to positive terminal on the speaker
- Screw Speaker back into the top cover
- Using two of the long screw, screw them into the top cover as far as they will go
- Using zip ties secure them in place on the top two zip ties in the main base of the path light
Step 6: Modification of Design Intent
- Remove the connector from the wires by pushing on the two tabs, some force by be required, use a blunt object so you don't hurt your fingers
- Cut 6" of speaker wire, 16 gauge
- Solder onto wire
- Cover with electrical tape
- Guide the wire through the coupler
- With some cardboard wrap the a pieces around the end of the post and secure (this is to protect the post if you want to reuse it).
- Guide the wire through the PVC pipe
- Wrap some cardboard around the PVC pipe and attach to other end of elbow coupler and tighten screw
- Reattach the connector
Note: if you try to use our little monster he will fall over cause he is not balanced
Step 7: Balancing of the Force
- Using the flat bar aluminum make a holder for the post
- Using a table vice grip make a 90 degree bend leaving 1.75" of material after bend. Bend was not straight, made it uneven so we can place the bar further back
- Make another 90 degree bend opposite of the bend you just made leaving at least 1.5" of material before bend
- Drill two holes for zip-ties at least 1.25" from bend
- Using dremel resize flat bar aluminum
- Flat bar aluminum was 36" in length, cut off 17.75"
- Use cardboard to line the inside of the groove that way the post does not get scratched up.
Step 8: Install and Play Music
Install your monster and connect to the Bluetooth and play your favorite scary music
