Mont Blanc Ball Pen Refill Mods for Pilot G2 Pen
Intro: Mont Blanc Ball Pen Refill Mods for Pilot G2 Pen
Modifications to a Mont Blanc Ball Pen refill for the Pilot G2 pen.
STEP 1:
Open the Pilot G2 pen and remove the G2 refill. (Figure 2)
STEP 2:
Remove the plastic tip protector from the Mont Blanc ball pen refill. (Figure 3)
STEP 3:
Using a knife (or sandpaper) trim the three fins located on one end of the tip protector to be flush with the tip protector body. (Figures 4 and 5)
STEP 4:
Now cut off a 12mm section from each end of the tip protector to yield two 12mm sections. (Figure 6)
STEP 5:
Put the 12mm section that has an opening on both ends onto the ball pen refill. (Figure 7)
STEP 6:
Drop the remaining 12mm section into the top barrel of the pen. (Figure 8)
STEP 7:
Insert the Mont Blanc refill and reassemble the pen. (Figure 9 and 10)
2 Comments
annerjx 7 years ago
This instructable is for the ball point pen refill not the gel refill. The ball point pen refill doesn't dry out.
StevenQ1 9 years ago
I've never seen a hack like this. I simply cut off the rear end of the Mont Blanc refill to make it the same height as the G2 refill. What can I say? It's a bit rough, the clicker sometimes doesn't allow the tip to retract, but it works well enough. I definitely like it a lot. The Mont Blanc refill works much better than the G2. I get more resistance from the Mont Blanc refill which allows me that extra control to form my cursive letters better.
