Introduction: Moped Chain Link Removal
Time for a new chain, but the new chain is too long? Or perhaps you're replacing one of your sprockets with less teeth, and the chain has too many links. No worries, we'll just remove a few links to shorten the chain.....
Oh, and FYI....
I made it at Techshop. They have a work bay where you can work on your car, motorcycle, moped... whatever! There are 3 of them around the SF Bay Area, so it's pretty convenient. There's others around the country and they have lots of tools and workshops. Wood, Metal, Fabrics, Electronics and more. It's rad.
Check it out here: www.techshop.ws
Step 1: Remove the MASTER LINK!
First, you might want to put some slack in the chain by loosening the rear wheel. I thought that I had taken some pictures of this, but alas, no. Most likely you'll just need to loosen the 2 axle bolts of the rear wheel and move it forward a little bit.
Now, locate the master link in the chain. There should be a link, with a clip on it, like the one in the picture. I generally move the chain so that the master link is on the UPPER portion of the chain. By that, I mean, The chain loops around the 2 sprockets. 1 on top, and one on bottom. If the master link is on the upper portion, the open part of the clip should be on the right. When you reassemble the chain, be sure to put the clip (Which we will now remove) back on this way. Kapish?
Once you've located and positioned the master link, take a pair of pliers, or channel locks, or needle nose pliers, and unclip the clip. I put 1 jaw of the pliers on the pin that the clip is snapped around, and the other jaw on the open portion of the clip. It should unclip relatively easily...
Once the clip has been removed from the first pin, it's pretty easy to wiggle it off. Do that. You will now see an oval link underneath where the clip was. This will also wiggle off. Do that.
At this point, the 2 pins of the master link are exposed. Simply undo and remove the master link.
Step 2: Break That Bad Chain!
Grab your trusty chain breaker tool. There are different types out there. The one I'm using is made by Motion Pro. It's okay. There is a pin in the center of the tool that will push out the pin in your chain link (from the link you want to remove). It is VERY IMPORTANT to back that pin up all the way, and screw down the larger, uh part, onto the chain. The chain breaker tool will become damaged if you don't back off the pin. Trust me. I've done it. It sucks.
So, screw down the bigger screwy thing onto the chain, snug. Then turn in the knob to start pushing in the pin. You'll want to put a wrench on the knob, or a screwdriver through the knob. I usually turn in 9 complete turns for a 415 chain.
After that, back up the knob 10 or 11 turns. Then unscrew the other part. You should be able to remove the chain breaker at this point.
You will see that the chain link pin is ALMOST completely out from the link, but not entirely. This is the preferred way to open the chain, because if you need to put the chain back together, the pin can be pushed back in fairly easily. If the pin comes all the way out, good luck trying to put it back in. Not fun.
At this point, just wiggle the loose link from side to side until it comes off.
Put the master link back on (in reverse order from taking it off) and Cha-BAMMM! Chain has been shortened.
