Introduction: Motion Triggered Camera
This is the second out of automatic camera trigger with arduino. In this instructable I'm going to show you how to make a motion triggered camera. This project detects motion in front of the camera and triggers the servo to click a pic in the camera.
Like the prevous version this is powered with a arduino.
Step 1: PARTS
The parts are simple and easy to find
Arduino
Camera
Motion sensor module
Servo
Step 2: Trigger
First lets start with placing the servo in a position to trigger the camera, my camera is fully analog with no electrical switch to trigger it so I used a servo to click the trigger . You may need wire connectors or you can go with hot glue to stick the servo on to the camera. By default I have set the servo to trigger the camera at 105*, but if your servo doesn't click the trigger the change this value in the arduino codes
servoMain.write(105);
Change the 105 to any higher value like 120.Connect the servo to the arduino. By default the servo is attached to digital pin 10. After you have done this its is time to connect the servo to arduino board. The servo has 3 wires the red goes to arduino 5v
, black to ground and orange or yellow is the signal pin and goes to digital pin 10.
Step 3: Code
Time to upload your code make sure that the Bluetooth module isn't connect to the arduino board, or the code wont upload to the board. Download the code from the attachment and upload it to your board. Now when that's done its time to set up the Motion sensor.
Step 4: Motion Sensor
Now time to add the motion sensor. I found this one on eBay, and this gives a high output every time there's motion in front of it. My motion sensor has a 270 angle and 5m range. So it works just perfect. The motion sensor goes to pin 11.
