Introduction: Motor Spinner
About: I like to build and try to get some of my projects on instructables. Or, at least the little ones.
I first made this thing when i was fooling around withe motors, attaching a battery and leting it spin out, it did not last too long because the battery would not stay on.
then i made a spinner with a battery attached to it, it worked well but it was loaded with duct tape, and it i could not change it easily.
I tried again to make a spinner. it worked very well and was open enough to change. this machine might not be too great but its fun enough. and yes there is NO SOLDERING! it only has on wheel and sort of hovers above the ground. but it is sort of hard to turn on.
Step 1: Parts and Tools
Parts
1 Small motor
1 Triple A battery
2 small paper clips
2 pieces of hard wire
1 small square of sheet metal 1 x 3 (optional)
1 wheel (bottle cap, Small wheel from RC car, Cork, Whatever)
1 zip tie
duct tape
Tools
Wire stripers
needle nose pliers
Scissors (or wire cutters on pliers)
Super glue or hot glue (you may not need this but you should still have it)
Step 2: Attaching Paper Clips to Battery
first dog-ear the paper clips so they are at a right angle with the pliers.
then put them on the battery, make sure they don't touch, you might want to put them on opposite sides.
put a piece of duct tape on the battery so the paperclips stay on.
Step 3: Attaching Wheel to Motor
Pretty simple, glue the wheel or whatever to the axle, or if you don't need to glue, dont, but the wheel might fly off when done.
Step 4: Adding Battery to Motor
Take Zip tie and clamp the battery to the motor. Make sure you put the battery on the opposite side of the motor. using pliers or scissors, cut the exsess Zip tie and get rid of it.
Step 5: Adding Hard Wire
Hard wire is just wire that is not woven and bends well, the wire that they use to hoold toys to there packages is perfect, but I use some other wire i found.
Cut the wire so you have about 3 inches. strip both ends of the wire and attach it, on side on the loop on the paperclip, on side on the loop on the motor. do this twice and the wheel should spin, if it doesent then a paperclip is too far from the battery, don't fix it now. Make sure you use the needle nose pliers to squish the hard wire to the loops in the paperclips and motor.
Step 6: Sheet Metal
For the sheet metal you will need a piece of duct tape. put the duct tape over the connections on the motor so the metal does not short-circuit it.
Just wrap the sheet metal around the Spinner so it is tight, make sure the sheet metal is the kind that does not unbend, if it does get another piece and find out that sheet metal does not unbend, you are just an idiot for not knowing how to bend it.
the sheet metal is very use full. it will protect your spinner and it will destribute the heat of the motor, making it not over heat. it also lets the body slide on the floor easier when starting up. The last obvious thing other than making it look totaly awesome is that it keeps the wires in place. you do not need this but it will help performance.
Step 7: The Finished Product
Now that you have finnished you can smell the roses and watch your small spinner romp around on the floor or table!
To turn it on just get the connections right by pressing the paperclips and hope it stays on, i don't have switches but that deffeats the simplicity.
make two of them and let them fight!!!
