Introduction: Motorcycle Pelican Case
I saw caribou cases and I thought instead of buying a 350$ top case for my motorcycle, I went to bandh.com and grabbed a hprc case for 80 bucks. I then went to ace hardware and spent about 15 bucks on screws and washers.
Step 1: Pull Off Rack From Bike
Lay your rack on top and measure to the center of the case. so you know where to drill the holes.
Put bolts through. My rack had spots for the bolts to lock into place. I put nuts there to raise the case since it is not flat on the bottom.
Step 2: Nylon Washers
Your case sits on these
Step 3: Mount Case
Mount the case and add your washers.
Step 4: Bolt It Down
I used lock nuts.
3 Comments
8 years ago on Introduction
Thats a great idea, except as a suggestion, I would mount it with carriage bolts through the case with the nuts on the bottom of the rack. It would give you a smoother surface in the case and less likely to snag things like your rain gear or (in some cases) laptop bag. I made that mistake when mounting a top box on my modified Suzuki Madura, I learned the hard way via a scratched visor.
Reply 6 years ago on Introduction
Only issue is that it makes it much easier for someone to steal your topcase by allowing access to the nuts...
Reply 8 years ago
That is true. I am putting pick and pluck foam along the bottom. which will cover the screws. Unfortunately I have to wait 2-4 weeks on that.
