Introduction: Motorized Recycled Plastic Bottle Glue Gun
hi
this is how I used a plastic bottle cutter as a source of glue gun
I used a glue gun hot end
and easy driver module for stepper motor driving
an Arduino UNO as a control board
and some rubber bearings
and some plastic strips recycled from a juice bottle
some screws and nuts.
Step 1: Step 1 : Glue Gun Hot End
easily extract he hot end from glue gun
Step 2: Step 2 : Making a Lead Way for Plastic Strip
I used a MDF sample board as a flat guide to hold things together
stepper motor will pull the strip and unravel it from spool that I'll make next.
but the stepper wont do it by its own, so I added a rubber washer on stepper motor gear and a rubber bearing next to it to make a friction.
Step 3: Step 3 : Spool and Guide
I attached the strip spool and a guide to the gears that pulls the strip
Step 4: Step 4 : Easy Driver Module and Arduino Uploads
simply uploaded code file to Arduino and wired the easy driver module to the UNO board to drive the stepper motor with a ON/OFF switch.
here is a sample to make the driver run for a default speed and etc.
but as you can see you have to make it comfortable as you plastic alloy
so I copied the default code so you can make it better for your own material.
and its really easy to find and edit Easydriver module codes and samples.
#define DISTANCE 3200
int StepCounter = 0;
int Stepping = false;
void setup() {
pinMode(8, OUTPUT);
pinMode(9, OUTPUT);
digitalWrite(8, LOW);
digitalWrite(9, LOW);
pinMode(3,INPUT); }
void loop() {
if (digitalRead(3) == LOW && Stepping == false) { Stepping = true; }
if (Stepping == true) {
digitalWrite(9, HIGH);
delay(1);
delay(1);
StepCounter = StepCounter + 1;
if (StepCounter == DISTANCE) { StepCounter = 0; Stepping = false; }
Step 5: Step 5 : Usage and Test
as you are aware I used it but because of time I couldn't make a proper housing for it cus i dont have a 3d printer yet.
but its really reliable and useful and i will try to prove it asap.
the temperature is fine and unraveling process is working just fine
the glue it makes is a bit loose so its more useful to me because glue gun glue bars takes space in some places that I don't want to use super glue and I need the space as well.
Plastic Contest
5 Comments
2 years ago
it'd be nice to see this in action!
2 years ago
Wow this is a game changer
Reply 2 years ago
thx for attention.
2 years ago
Very intriguing idea. Thanks for sharing!
Reply 2 years ago
You're welcome mate.
wanna save some to make it bigger and more useful
cheers
