Introduction: Mount a TV Without Putting Holes in the Wall
This is a guide on how to mount a TV without putting holes in the wall and cheaply. Some background, I live in a college dorm and we are not allowed to put holes in the wall so I decided I would build a "fake wall" using just tension between the ceiling and floor.
Things you will need:
- A TV to mount
- A normal TV wall mount
- 2 - 2x4's long enough to go from floor to ceiling (make sure you buy good quality)
- 4 - 4x4 pieces of 3/4 plywood or what ever you have lying around that can distribute the weight
- Normal wood shims
- optional 2 - 4x4 pieces of foam to protect ceiling.
If you like this Intructable please vote for me in "On a Budget" contest and the "Small spaces" contest.
Step 1: Measure and Cut Wood
First things first find out where you want to mount the TV and make sure it will fit.
Next, measure how far apart you want your beams it varies with every TV mount I used tape on the floor and ceiling to make leveling easier.
Measure from floor to ceiling then subtract out the exact thickness of the plywood twice (one will go on the floor the other on the ceiling). If you are using foam then subtract about half the thickness.
Now you want to cut make sure when cutting the beams you cut a little smaller to allow for the shims.
Step 2: Put It Up
This part is a little tricky set it up like the photos first put the plywood piece on the floor with a shim on top. Put the beam on top of that, the easiest way to get it up is to put the piece of plywood in place on the ceiling the wedge the beam under it so its tight.
To tighten you want to hold the beam and hammer the shims as far as you can. See if you can pull the beam done with your weight if you can move it it needs to be tighter.
Step 3: Mount the Mount
Next, put up the TV mount I used bolts with washers, lock washers, and nuts but you can use a traditional wood screw if you are careful not to split the beam. Also make sure you use a level my mount had a level installed on it. Once you have the mount up try it with your body weight if it holds your golden!
Lastly put the TV up!
