Introduction: Mount a Vise!
Simple instructions for mounting a Vise!
Step 1: The GIG.
So, I have a vise, that I would eventually like to use.
It's red, it's rustyish. But it works well, I think.
So I think I will mount it..... but need to use some tools to do so, as to not break anything.
Basically the tools are as follows: Drill, drill bit, i used half inch lag bolts, a half inch driver, a marker, and a table.
Step 2: Precautions.......
We are going to be using a drill. Drill bits can and will drill through things, including body parts. Please do not do that. But if you happen to try it out, remember that I AM NOT RESPONSIBLE FOR YOUR TESTING, or TESTING RESULTS... Also, please wear safety glasses!
With that out of the way.....
Step 3: Where Is Your Vise Going?
So, once you know where you want to mount your vise, use a pencil or marker to mark where.
Then, please drill a hole smaller than the bolts you are using.
Step 4: Mount It Up!
Put that there Vise into place and then hand tighten the bolts. You then use the half inch bit to tighten them down!
Step 5: All Done!
Enjoy your mounted vise, and make some Instructables with it!
