Introduction: Mousebot Revisited
Mousebot from Make vol 2 is a fun introduction to robotics. So fun that I've created this expanded documentation of a Mousey build from start to finish, with a few extra little tips you won't find in the mag. This how-to is best understood after reading the original article from page 100 of Make vol 2 however it is probably not required.
Mousebot is a simple bot that uses two "eyes" to sense light and then turns towards the light. A single large "whisker" is mounted on the front of the mouse to detect collisions. A collision with a wall will cause the mouse to reverse and turn then take off in another direction. This project is pretty cheap, if you have a mouse to use the other parts can be obtained for less than ten dollars.
If you have any questions or comments you can get me at jacob@makezine.com
Step 1: Gather Materials and Tools
MATERIALS
1 Ball Mouse
2 Small DC Motors
1 Toggle Switch
1 DPDT 5v Relay (Aromat DS2YE-S-DC5V works)
1 LM386 op-amp
1 2N3904 or PN2222 NPN Transistor
1 LED (any color)
1 1K Resistor
1 10K Resistor
1 100uF Electrolytic Capacitor
1 Audio Cassette Tape (you know, from the 80s...)
1 CD-ROM or Floppy Disk (for the bumper)
1 9V Battery Snap
1 9V Battery
2 or 3 Wide Rubber Bands
22 or 24 Gauge Wire (some stranded and some solid core)
TOOLS
Multimeter
Phillips screwdriver
Dremel
Small pliers
Wire cutter/stripper
Razor knife
Soldering iron
Desoldering tool of choice
Superglue or epoxy
Hot glue gun and glue
Hacksaw
Step 2: Scavenge Some Parts
The Mousebot requires several parts which we can conveniently borrow from the donor mouse, its eyes and its whisker.
Open up the mouse and locate the components that we'll be harvesting, the momentary switch and the infrared emitters (the clear ones).
Remove the PCB and desolder the push switch and both IR emitters.
Step 3: Prepare the Case
Next we need to give Mousebots insides a cozy place to reside, so break out the Dremel and remove all of the internal plastic structure from the top and bottom of the mouse. If your mouse is small you may have to remove the screw posts that hold the mouse together.
Now use the Dremel to cut openings for the bump switch in the front of the mouse and motors on the sides.
The best Dremel bit to use for this is the short cylindrical type, it will cut a good right angle if the Dremel is held vertically.
Step 4: Make the Wheels
The axles on these motors are pretty small and if we want Mousebot to be stable at blazing high speeds we need to make him some rims. Cassette tapes have a rim of perfect size in the bottom right and left corners (if the open side is down). It might take a couple tries opening different brands of tapes before you get ones that fit your axles perfectly. Once you find some rims you are happy with super glue them to the axles.
Cut the rubber band and superglue it to the rim then wrap it around three times, adding superglue every half turn or so to keep it together. Cut off the leftover rubber.
Now glue another rubber band back to the one that you just wrapped. Complete one revolution and cut off the extra. Make sure to add enough glue to keep the outside rubber band on. Repeat the same process for the other wheel
Step 5: Layout the Design and Install the Relay
There are quite a few good component layouts for the mousebot. The best layout is probably the one picture on the top of page 100 of vol 2. However this alternate setup pictured below works better on certain mice. I chose to use the standard layout. The circuitry of the mouse will be free formed since there is not much extra room for a pc board.
Once we know where everything will go its time to get to the real work. Set down the relay and solder wires in an X connecting pins 8 to 11 and 6 to 9. (see pin labels on second image)
Then connect pins 1 and 8 with a wire along the side and add stranded wire to leads 8 and 9.
Solder the collector of the transistor (right pin looking at the flat side) to pin 16 and clip the lead short. Then connect the wire we soldered to pin 9 to the emitter (left pin looking at the flat side) leaving a little bit of slack.
Now glue the relay into the case. I have added two clipped leads to act as positive and negative voltage rails which will get rid of some clutter in the motor area. Use your razor knife to strip the shielding from the wire connecting pin 9 and the emitter and solder it to the - voltage rail. Then connect pin 8 to the + voltage rail.
Step 6: Install the Bump Switch
Now lets give the Mousebot his whisker. Make it by soldering the positive lead of the capacitor and the 10k resistor to the end pin that is normally open. You can check which side is the open side of the push switch by using the continuity check feature of your multimeter. There should be no connection between the middle and normally open pin until the switch is pressed. Once this is done add stranded wire to the ground lead of the capacitor and the middle pin of the switch.
Connect the resistor on the switch to the base (middle pin) of the transistor and the wire from the ground side of the capacitor to the - voltage rail. Then connect the middle pin to the + voltage rail. To make your joints a bit more secure you can use heat shrink tubing to insulate the connections and bend the capacitor to the side to free up a little bit more space.
Step 7: Build Mousebots Brain
Mousebots brain is the LM386, flip it on its back (pins up) and bend pins 1 and 8 so that they are touching and add some solder.
Now place the 386 into position and connect pin 4 to the - rail, pin 6 to the + rail and add stranded wire to pins 2, 3 and 5.
We are almost ready to connect the motors so solder some stranded wire to pins 4 and 13 of the relay. At this point your Mousebot should look something like the third picture on this page.
Step 8: Construct Mousebots Top Half
First drill three small holes at the front of the mouse for the two eyes and sensitivity boosting LED. Then drill a larger hole for your toggle switch at the back of the mouse and install the switch to form mousebots on/off tail.
To create mousebots eyestalks twist two pieces of solid core wire together and solder the IR emitter to the leads on one end. Place the LED in the middle hole and connect the + lead to the 1k resistor.
Next use the diode check feature of your multimeter to find the - leads of the IR emitters and connect them to the - lead of the LED.
Step 9: Glue Down the Components
Use hot glue or epoxy to secure the bump switch and the motors to the mouse chassis. I used a combination of superglue and hot glue to hold in the bump switch and hot glue on the motors. Make sure the angle of the motors are roughly equal and extend down enough to raise the front of the mouse slightly off of the ground.
Step 10: Finish Up Making Connections
Connect pin 13 of the relay to the left motor and pin 4 of the relay to the right motor. Now connect pin 5 of the IC (brown wire in picture) to the ground node of both motors. If you arent sure which side is + and which - on you motor connect it to a battery and observe the direction of the spin. The right motor should spin clockwise if you are looking at the wheel and the left should spin counter-clockwise.
Locate the wire coming from IC pin 2 (green) to the + lead of the left eyestalk and IC pin 3 (blue) to the + lead of the right eyestalk. Then wire the 1k resistor to the + voltage rail.
Hook up the battery by soldering the black wire on the battery cap to the negative voltage rail. Connect the red wire on the battery cap to the switch and then connect the switch back to the + voltage rail.
Replace the cover of the mouse and then cut a thin strip of your bumper material (CD) with the hacksaw. Attach the strip with epoxy or hot glue on one side so that wherever you apply pressure the button clicks. Once you have the strip attached give yourself a pat on the back, you're done.
Flip the switch and enjoy.
The Instructables Book Contest
463 Comments
12 years ago on Step 5
can i use a 12vdc relay, or can i use two relays?
Reply 12 years ago on Introduction
The number on the relay is telling you how many volts are required to trigger the switch by sending the voltage through a coil between two pins. If your robot uses a 9VDC battery, then you will need a relay that can be triggered by about 5 or 6 VDC. A standard 9V battery won't trigger a 12VDC relay.
You want one Double Pole Double Throw (DPDT) relay rated for 5VDC or two Single Pole Double Through (SPDT) relays rated for 5VDC.
You can purchase and appropriate 5V DPDT relay from Solarbotics or just read more about how they work on their site. http://solarbotics.com/products/re1/
Hope this helps.
Sincerely,
Christin Boyd
http://robotfun.wordpress.com
Reply 5 years ago
Thanks to Christin too. Even though this is 6 years ago from now, I just read Christin's article on trouble shooting. Would have been better if I had read it before! I will try the things Christin mentioned and see if I can get some improvements to mine. I put a 10 ohm resistor so will try 200 ohm resistor on the IC instead. Thanks!!
which one is correcthttps://cdn.instructables.com/FFS/NUTG/SRBEUXWQNIO/FFSNUTGSRBEUXWQNIO.LARGE.jpg pliz help
8 years ago on Introduction
please give me a video making !!!
17 years ago
I finished my Mousebot over the weekend. It works perfectly thanks to the correct schematic at: http://streettech.com/robotbook/circuitMousey.html. The kids and cat are impressed. I made a rubber bumper by cutting a rubber washer in half and hot glueing it around the front of the mouse over the switch. Several mechanical challenges. The case doesn't close completely so I'm holding it together with rubber bands. And the back end is so battery heavy that it often can't get enough torque to back up. And it likes to circle to the left which is actually a nice feature - less mouse chasing.
I learned a lot from this project and it really got my interest up in BEAM bots.
this schematic https://cdn.instructables.com/FFS/NUTG/SRBEUXWQNIO/FFSNUTGSRBEUXWQNIO.LARGE.jpg is better that the first init pliiiz repliie
thank you
awesome stuff .. gonna try that on my mouse
yep great
9 years ago on Introduction
how many is it the DC dynamo size? and the size of relay? Please help :)
9 years ago on Step 2
All I have is a LM358n. Will this work?
Anybody?
yes it should...
This is a textbook quality Instructable !! Clear and concise - PERFECT!
Thanks!!
This is a really neat project. Where can I get all of these things?
RIP Donor mouse.
Hey, I just finished mine but unfortunately it does not work. Don't know what I'm doing wrong... One motor spins real fast & the other spins really slow.
Thought I had done some wiring mistake the first time & re-wired the whole thing again, but still the same issue.
Any guess's, adding in a pic of what I have as if now though.
Reply 11 years ago on Introduction
hey dude i had the sam problem; once he had a circuit here and its different from the stuff he tells u; search for the circuit, it might be in the pdf
put a 200 ohms resistor 1 to 8 of the lm386
