Introduction: Mousetrap Car
Mousetrap Car let me give you some reasons why you might want to make a mousetrap car
1. One reason is its fun to make it
2. And its fun craft it inclueds art and decorating
3. its sort of easy to make if you try
Step 1: Mousetrap Car
1. Mouse trap 1
2. 4 CD’s
3. 8 Wooden sticks
4.17 by 18 square cardboard
5. Hook
6.Construction paper
7. Tape
8.string
9. 2 Straws
10.Hot glue
Step 2: Decorating the Wheels
Cut a round circle the same size as the CD and hot glue it to the wheel
Step 3: Making the Hole for the Wheel
First get the CD and poke a hole in the middle and check with the stick to see if it fits
Step 4: Making More
Do the same thing from step 2 and do it four times
Step 5: Taking the Hook of the Mousetrap
On the mousetrap you’ll notice that there is a hook on the mousetrap grab it and take it off
Step 6: Making the Wheels
First get the stick poke it through the wheel and hot glue it
Step 7: Double It
Make to sets of wheels
Step 8: Making It Spin
Cut a straw in half and keep cutting it in half until the last two pieces is what your going to use
Step 9: Making the Body
Hot glue the mousetrap to the middle centur once that’s done hot glue the wheel to the body
Step 10: Extending It
Hot glue both sticks on both sides
Step 11: Making the Winder
Get a stick and cut it in half and then Hot glue the stick to the side of the mousetrap
Step 12: Holding It Up
Cut two squares and hot glue it to the other sticks
Step 13: The Hook
Get the hook from your mousetrap and hot glue it on the bottom stick
Step 14: Conclusion
Once you do step 12 it should be finished
