Introduction: Robot Moving Paper Can
I made it because I thought it was a cool Idea.
Three pieces of paper a large square of cardboard a robot * This is the robot we will be working on to build this IDk the name so we will just call it robot. Two IR sensors four wires and four resistors two of them should be 220 ohms and the rest should be 1k ohms
Step 1: Measure Base
I first measured the robot's size to determine how big I needed to build the base. You need the base so that you can build the body around it. 15 is the length of the robot and 12 is the width. The smaller numbers on the bottom are a way to build the base by determining the circumference although it is an oval and not a circle.
Step 2: Cut to Size
Then when you have an oval cut the back and make sure the back of the robot lines up then mark where the wheels will go and cut them you can mark them with anything because you are going to have to cut it wide.
Step 3: Electronics
This is the electronics that you going to need and here are where they should go the black wire that is connected to the yellow one should go to the Vss and the red one should go to Vdd there are a set of IR sensors the speaker is unimportant so you can include it but I dont have code for it.
Step 4: Case
Then put yellow construction paper you're going to need two pieces of paper and attach them to both each other and the bottom then cut wherever the eyes are and make sure that it is big enough so that the sensors can do their job. Plug in this code next I am using ParalaxIDE.
Step 5: Code
Here is code again I am using ParalaxIDE and dont add the quotation marks at the beginning and the end.
“Boop VAR Word 'VARIABLE
Beep VAR Word 'VARIABLE
Bap VAR Word 'VARIABLE
irDetectLeft VAR Bit 'VARIABLE
irDetectRight VAR Bit 'VARIABLE
DEBUG"IR DETECTORS", CR, 'TELLS YOU WHEN SPEAKER IS GOING TO SOUND
"LEFT RIGHT", CR, 'TELLS YOU DIFFERENCE FOR SIGNAL
DO
FREQOUT 8, 1, 38500'THE INFRARED SIGNAL
irDetectLeft = IN9'THE RECEIVER FOR LEFT
FREQOUT 2, 1, 38500'THE INFRARED SIGNAL
irDetectRight = IN0'THE RECEIVER FOR RIGHT
IF (IN9 = 0) AND (IN0 = 0) THEN 'Nothing go forward
FOR Boop = 1 to 200
PULSOUT 12,850
PULSOUT 13,650
NEXT
FOR Beep = 1 to 100
PULSOUT 12,650
PULSOUT 13,650
NEXT
ELSEIF (IN9 = 0) THEN 'Thing on Left
FOR Beep = 1 TO 50
PULSOUT 12, 850
PULSOUT 13, 750
NEXT
ELSEIF (IN0 = 0) THEN 'Thing on Right
FOR Beep = 1 TO 50
PULSOUT 12, 750
PULSOUT 13, 650
NEXT
ELSEIF (IN9 = 1) AND (IN0 = 1) THEN
FOR Bap = 1 TO 50
PULSOUT 12, 650
PULSOUT 13, 850
NEXT
ENDIF
DEBUG CRSRXY, 2, 3, BIN1 irDetectLeft 'SHOWS IF IT GETS A SIGNAL
DEBUG CRSRXY, 9, 3, BIN1 irDetectRight 'SHOWS IF IT GETS A SIGNAL
PAUSE 100
LOOP”
Step 6: Top
Finally put the robot in the case and include the battery it should fit just perfectly with the battery and add a top it can be a piece of paper just tape the top on.
