Introduction: Moving Moss
Make an illusion of moss moving on top of a box so when you pet it it, comes towards you, and moves like it is breathing. Using magnets and Arduino with moving sensor made the illusion.
Material:
Bookbinding paper
wooden plates for sides and bottom
2 strong magnets
moss and stones
linear gear mechanism
2 Arduino
2 Servo
moving sensor or light sensor
Tools:
Glue
Saw
Laser cutter
Step 1: Make the Box and Linear Gear Mechanism
First step is making a box with strong sides and bottom, then bookbinding paper on top. Does not matter the size.
sow the wooden plates but laser cut the bookbinding paper. Then glue it all together.
Make a linear motion, I used the "laser cut Linear Actuator" by Zarify.
https://www.thingiverse.com/thing:3506865
Then glue that on the backside if the bookbinding paper.
Step 2: Make the Moss Move
Place the magnets on, one on the gear and one to the moss.
Connect the Servo and Arduino(can download the one in links) with movement sensor and try it out!
Step 3: Make Second Motion, Breathing Motion
Second motion is more simple and all you need is a servo and stick to glue onto the servo.
Make a cut on the paper where you want the motion to be. Place the servo connected with the stick underneath the cut so it can move within the cut.
Linked is the Arduino motion for this movement.
Step 4: Decorate the Box and Hide the Sensor
You can do this how you like but make sure people do not see the motion sensor to make the illusion motion
