Introduction: Mr. Goalie
This instructable was created in fulfillment of the project requirement of the Makecourse at the University of South Florida (www.makecourse.com)
Step 1: Download Parts
Go to: https://grabcad.com/library/embaixadinhas-wooden-t...
(If you do not already have one, you will need to create a GRABCAD account to access files.)
Click the downlaod all files button
Extract Files from the zip folder to a new folder
Step 2: Extract .rar File
Go to: https://extract.me/
Find the "STEP_Embaixadinhas.rar" file in the folder with the extracted files.
Upload and extract
Step 3: Open Assembly in Solidworks
Open SOLIDWORKS
Find and open extracted STEP file from previous step
Step 4: Save Parts
Double click individual parts of the assembly.
Right click highlighted part in assembly tree to the left.
Select invert selection.
Right click any highlighted selection.
Select suppress.
Save As part as a .sldprt file
Step 5: Repeat
Repeat STEP 5 until all parts needed for assembly have been saved.
Individual parts can also be edited.
Step 6: Assemble
Assemble parts in SOLIDWORKS and create mates to form figure in the position of a hockey goalie.
Save As ".stl" file and have it 3D printed.
Step 7: Repeat STEP 6
Repeat STEP 6 in form of a shooting hockey forward.
Step 8: Setup
Using an Arduino Uno, a breadboard, 6 push buttons and 2 servo motors complete the pictured setup.
Step 9: Commented Code
#include //include servo library
Servo myservo; //create servo object to control servo 1 Servo servo2; //create servo object to control servo 2
int pos; //variable to store servo 1's position int pos2; //variable to store servo 2's position
void setup(){ //setup pins
pinMode(2,INPUT); //push-button 1: slow mode
pinMode(3,INPUT); //push-button 2: moderate mode
pinMode(4,INPUT); //push-button 3: fast mode
pinMode(5,INPUT); //push-button 4: shoot
pinMode(6,INPUT); //push-button 5: reset
pinMode(7,INPUT); //push-button 6: stop
digitalWrite(2,HIGH); //while the button is unpressed the state of the pin is HIGH
digitalWrite(3,HIGH);
digitalWrite(4,HIGH);
digitalWrite(5,HIGH);
digitalWrite(6,HIGH);
digitalWrite(7,HIGH);
myservo.attach(9); //attaches servo 1 on pin 9 to the servo object
servo2.attach(8); //attaches servo 2 on pin 8 to the servo object
pos = 90; //intial position for servo 1
pos2 = 180; //intial position for servo 2
} //end setupvoid loop(){ //main loop
myservo.write(pos); //moves servo 1 to intial position
servo2.write(pos2); //moves servo 2 to intial position
if (digitalRead(2)==LOW){ //if push-button 1 is pressed
do{
for(pos = 5; pos <= 175; pos += 1){ //servo goes from 0 degrees to 180 degrees in steps of 1 degree
myservo.write(pos); //tells servo to go to position in variable 'pos'
delay(15); //time between iterations in miiliseconds
pos = pos; //updated position
if (digitalRead(5)==LOW){ //if push-button 4 is pressed
servo2.write(0); //moves servo 2 to 90 degrees
if (digitalRead(6)==LOW){ //if push-button 5 is pressed
servo2.write(180); //moves servo 2 to intial position
for (pos = 175; pos >= 5; pos -= 1) { //servo goes from 180 degrees to 0 degrees in steps of 1 degree
}while(digitalRead(7)==HIGH); //if push-button 6 is pressed exits do_while loop
} if (digitalRead(3)==LOW){ //if push-button 2 is pressed
do{
delay(10); //time between iterations in miiliseconds
} if (digitalRead(4)==LOW){ //if push-button 3 is pressed
do{
delay(5); //time between iterations in miiliseconds
}//end main loopStep 10: Enclosure
Pick an enclosure to build your project around.
(pictured is what was used for this setup)
Step 11: Linear Gear
Attach Goalie to linear Gear
Mate linear gear to spur gear connected to servo motor
Step 12: Put Together
Drills holes in the top of the enclosure for the push buttons, the goalies track, and the forward.
Step 13:
Wire Arduino to breadboard as shown in STEP 8
Conceal all wiring and nonessential parts in enclosure
(may require soldering for wired connections to push buttons)
Project Complete
