Introduction: Mr.paper Whistles!
in this instructable, i will teach you how to make whistling noises with common paper.
Step 1: Grab a Paper!
to make a whistling noises with paper, first take a paper. A4 papers would be good. you can cut it up in a strip in length about 10cm, to make it easier to hold.
Step 2: Hold It Tight!
you hold your paper with your index finger and thumb, like it is in the image. hold it tightly.
Step 3: Blow It!
blow your paper from about a mm away and blow straight. change the direction of the paper or move it around until it vibrates(it vibrates a lot) and make piercing noises. if you blow it for too long, the paper would dampen. if your paper doesn't sound well after blowing for a long time, change it and try again.
Thank you for reading this lousy instructable.
