Introduction: Muleta Cross
Hello! Thank you for checking my project.
Step 1: Problem
Crutches have poor grip and contact area, especially when tilted, so they slip on ceramic materials and sink into the sand.
Step 2: Solution
Greater contact area allows for more stability on both tiled and sandy soils.
Step 3: Just Fit in and That's It!
Designed to lock under pressure. Single piece, 100% plastic.
Step 4: Firm and Articulate
The Muleta Cross fitting allows the cradle to be tilted at 30 degrees, which improves movement and allows its surface to always be in contact with the ground.
Step 5: Light and Agile
The holes in the sole of the Muleta Cross also facilitate the flow of sand, water and even air. As the support gets lighter, it avoids unnecessary weight and drag at the time of movement. The holes also structure the sole, leaving the piece more resistant.
Step 6: Rubbed
Its rubberized texture ensures that the sole does not loosen and stays firm even on wet floors.
Step 7: The Project
On cold, slippery floors or sandy soils, the crutch never seemed firm and safe enough. I once had the opportunity to use it on the beach, in the fine sand. It was neither pleasurable nor practical. This difficulty bothered me, thinking of people who are constantly dependent on their use. Muleta Cross was born from this experience - a project that facilitates the locomotion and gives greater security in any type of floor and ground. To reach the final result, numerous updates have been made, with the aim of improving cost-effectiveness without compromising quality and usability. Such optimizations reduced the initial design value by five times.
Step 8: Designed to 3D Printing
It can be printed in 5 hours with a resolution of 0.3 mm and 15% of Infill. You can chose any material you want to print. I recommend a rubbed material or the old and good ABS.
Thanks for knowing my project. Check my site to know more projects like this and also check the complete page of this project
