Multi-Function Walking Stick - Converts to a Chair
Intro: Multi-Function Walking Stick - Converts to a Chair
Trying to find a place to rest on the trail can be a challenge; especially when the woods are wet.
Carrying a camp chair in your pack seems like an unnecessary luxury, however, if the hiking stick you were planning on carrying anyway could serve as a lounge chair, you just might want to indulge.
This Instructable describes the steps for making a convertible walking stick with an accessory seat. At a height of 6 feet when fully assembled, the walking stick is really more of a Hiking Staff however, the 3 piece design makes it easy to transport and allows it to convert into a seat.
But there's more...
This is the first in a series of Instructables demonstrating the versatility of this Hiking Staff. Subscribe if you don't want to miss the next two sequel Instructables:
- Decorative and functional copper shod finial staff ends with storage
- Staff-top provision for an illuminating torch
STEP 1: Staff Size
(3) 1” diameter hard wood dowels (each 2 feet in length). I used oak for this project.
A grip near the top of a taller staff allows it to extend well downhill while the body remains upright during a descent.
The only negative I have found with a Hiking Staff is the inevitable accusation of sheep herding or the resemblance to Moses (which happens despite the lack of beard credentials) .
STEP 2: Add the Copper Connectors
(2) 3/4" diameter sweat fitting to 1/2" threaded male copper plumbing fitting
(2) 3/4" diameter sweat fitting to 1/2" threaded female copper plumbing fitting
The outer diameter of the 3/4" sweat fitting matches the 1" diameter of the wood dowel. This creates a nice flush transition at the wood to copper interface.
(Be sure to use 3/4" sweat to 1/2" threaded reducer fitting. The diameter of 3/4" sweat to 3/4" threaded fitting will be too large to fit through the ring used to assemble the seat.)
(1) Package of two part epoxy adhesive
- Brandname “JB Weld Epoxy” adhesive holds well on metal.
- Make sure to use the original JB Weld that requires 24 hours to cure.
- Do not use the quick cure (15 minute or less epoxies - including JB Weld Quick) as these
do not hold as well to metal
1: Use sand paper (or chisel, pocket knife, lath or beaver teeth) to reduce the diameter on one end of the Upper Section and Lower Section dowels to match the inside contour of the female copper fittings. The dowel ends should insert to the bottom of the threads on the female fittings.
Both ends of the Middle Section dowel should be reduced to fit the male copper fitting. This dowel should insert all the way to the end of the male cooper fittings. (The male fitting requires the dowel to have two step diameter reduction in order for the dowel to fit flush to the end of the fitting.)
Reference the last photo in this series.
2: Test fit the dowel in the copper fittings several times as you are reducing the dowel diameter. The dowel needs to press tightly into the fitting. Use a mallet to force the fittings on (be careful to not damage the threads.)
Note: The fitting will ultimately have to be removed to apply the adhesive. This is where the wrench flats on the fitting come in handy. Use them to twist off the fitting.
3: Remove the fittings and “roughen-up” the inside of the fitting with something sharp (like the bent point of a nail or a file.) The deeper the gouges / scores on the inside of the fitting the better the adhesive has something to grip onto.
4: Similarly,“roughen-up” the end of the wood dowel by making grooves to hold the adhesive.
5: Mix the adhesive per the package instructions. Protect the threads on the fitting with tape. Apply adhesive to the inside of the fittings, and the ends of the dowels. - Make sure adhesive does not get on the threads.
6: Pound the fittings on the dowel ends and clean-up any adhesive that oozes out. Again, make sure the threads are free of adhesive.
STEP 3: Drill Seat Pin Holes
1. Drill a 3/16" hole 2" deep into the center of the dowels at the fittings on the Upper Section and Lower Section .
2. Drill a hole in only one end of the Middle Section.
STEP 4: Add Pivot Notches
(1) 2" inner diameter welded chrome ring. (Typically found in the hardware store near the chains.)
This is the Pivot Ring (reference the last photo in this series) it holds the center of the dowel sections allowing them to flare out.
Two notches are required In the center of each dowel section to accept the Pivot Ring.
1. Make the the first notch perpendicular, straight across the dowel. (I used a file to make the notch)
2. File the second notch at a 30 degree angle.
The notches should be about 1/4" wide and 3/8" deep.
the perpendicular notch is for the initial positioning of the dowels when they are loaded into the Pivot Ring. The angled notch accommodates the splayed position of the legs when forming a tripod.
STEP 5: Sew the Canvas Seat
(2) Pieces heavy canvas (approximately 14"x14")
Heavy duty Polyester thread
1: Cut two pieces of canvas into triangles (14" per side)
2: Sew the two pieces together along the three sides. Stop the sew lines about 2 inches short on each end
3: Turn the sewn together pieces of fabric inside-out through one of the openings at a corner of the triangle .
4: Fold over each edge of the triangle to a width of about 3/4 inch and sew. This will form a "sleeve" along each side of the triangle.
STEP 6: Thread the Cable
Reinforcement Material:
1/8" Stainless Steel Cable (Approximately 24" in length)
(1) 1/8" Aluminum double Ferrule (reference last photo in this series)
(3) 2" long Stainless Steel Cotter Pins
1: Thread the cable through the "sleeves" in the seat fabric. The cable holds the top of the dowel sections in position preventing them from over splaying.
2: insert the ends of the cable into the ferrule and crimp. A 5lb sledge hammer worked well to compress the ferrule.
3: Open the three cotter pins and load over the cable at the tree corners of the triangle. These are the Seat Pins used to attach the seat fabric to the dowel sections.
(The open legs of the pin act like a spring to hold them in the dowel holes.)
STEP 7: Assemble the Seat
Load the Upper Section, Lower Section and Middle Section through the Pivot Ring.
Make sure the ring is in the notch of each section as the next section is loaded.
STEP 8: Form the Tripod
The splayed dowels will form tripod legs.
STEP 9: Insert the Seat Pins
STEP 10: Seat Complete
I created a logo for our Boy Scout Troop using a graphics program and printed it out on iron-on transfer paper. (this paper is readily available at any office supply store.) It bonded well to the cotton canvas fabric. (Remember that any iron-on transfer needs to be printed in reverse.)
STEP 11: Seat in Action
Now if only it reclined and had a foot rest....
Below you can see the Hiking Staff Seat in conjunction with the light weight Backpacking Table described in the following Instructable: https://www.instructables.com/id/Camp-Table-for-Backpacking/
137 Comments
Art4Med 8 months ago
Also, the hexagonal corners of the fittings can be rounded for weight and contour savings. A commenter on PartIII put a hardened bolt in the tip before epoxy and that’s a huge gain in longevity. Other wood dowels can be substituted for weight savings if the grains are straight, but strength is key to use: this staff will always be a heavy companion, and older hikers will prefer hiking sticks!
BillyR54 1 year ago
Art4Med 9 months ago
tw0nst3r 8 years ago
I'm planning on making one of these over these next few weekends, with some modifications:
· I hope to use paracord as the seat support; several lines around the outer triangle will serve as a framework for weaving a net. The net should provide extra support under the canvas (I'm a big boy). I still need to figure out how to protect the paracord lines at the corners from the cotter pins - maybe a plastic sheath at those points?
· I'll also use paracord instead of the ring, either a simple wrap several times around with a clove hitch to secure, or a full-out tripod lashing.
· I'm installing male connectors at top and bottom.
· I found an iron cap in the plumbing section that fits the male connector - it looks sturdy. I'll install that on the bottom to take the repetitive impact when hiking.
I'll try to remember to take pics of the differences, and will update the post once completed to let everyone know how it works. If it works well, it will go with me to the Boundary Waters Canoe Area this spring, and to Devil's Den State Park in the summer. It will then be a regular part of my backpacking gear!
Peace and Long Life,
Twonster
Lorddrake 8 years ago
how did it turn out?
onesimpleidea 8 years ago
Hi. You might have answered this already: Is there an important reason for the connectors to be made of copper vs. some other material?
madjackshome 1 year ago
kodeyg93 1 year ago
cwjones2 4 years ago
kodeyg93 1 year ago
G-Taylor 1 year ago
https://www.homedepot.com/p/Everbilt-3-4-in-x-1-2-...
Here are the links I found on Home Depots website for what looks like the correct ones, hope this helps!
BrianQ13 4 years ago
metras3 1 year ago
I love this idea and will start working on it next week! Pictures to follow!
JoeR112 7 years ago
Elkhart #30500 1/2x6 COP Air Chamber
Amazon
Blue Hawaii 5 years ago
fantasma2045 5 years ago
very useful outdoors, very cool
Loonieone 8 years ago
Very cool! I plan on making one for myself and scaled down ones for the 2 boys ( aged 9 and 10) that I spend time with hiking and camping.
paulgs15147 7 years ago
I looked at using PVC, but there is quite a difference between the hole of the cooper and the outside of the PVC. So there has to be a lot of glue or, there has to be a lot of material taken from the PVC to fit. How did you handle that?
