Introduction: Multi-Function Walking Stick - Converts to a Chair
Wouldn't it be nice if your walking stick served double duty as a chair? This walking stick functions just as well as a stationary resting device as well as it does as amobility enabler.
Trying to find a place to rest on the trail can be a challenge; especially when the woods are wet.
Carrying a camp chair in your pack seems like an unnecessary luxury, however, if the hiking stick you were planning on carrying anyway could serve as a lounge chair, you just might want to indulge.
This Instructable describes the steps for making a convertible walking stick with an accessory seat. At a height of 6 feet when fully assembled, the walking stick is really more of a Hiking Staff however, the 3 piece design makes it easy to transport and allows it to convert into a seat.
But there's more...
This is the first in a series of Instructables demonstrating the versatility of this Hiking Staff. Subscribe if you don't want to miss the next two sequel Instructables:
- Decorative and functional copper shod finial staff ends with storage
- Staff-top provision for an illuminating torch
Step 1: Staff Size
(3) 1” diameter hard wood dowels (each 2 feet in length). I used oak for this project.
A grip near the top of a taller staff allows it to extend well downhill while the body remains upright during a descent.
The only negative I have found with a Hiking Staff is the inevitable accusation of sheep herding or the resemblance to Moses (which happens despite the lack of beard credentials) .
Step 2: Add the Copper Connectors
(2) 3/4" diameter sweat fitting to 1/2" threaded male copper plumbing fitting
(2) 3/4" diameter sweat fitting to 1/2" threaded female copper plumbing fitting
The outer diameter of the 3/4" sweat fitting matches the 1" diameter of the wood dowel. This creates a nice flush transition at the wood to copper interface.
(Be sure to use 3/4" sweat to 1/2" threaded reducer fitting. The diameter of 3/4" sweat to 3/4" threaded fitting will be too large to fit through the ring used to assemble the seat.)
(1) Package of two part epoxy adhesive
- Brandname “JB Weld Epoxy” adhesive holds well on metal.
- Make sure to use the original JB Weld that requires 24 hours to cure.
- Do not use the quick cure (15 minute or less epoxies - including JB Weld Quick) as these
do not hold as well to metal
1: Use sand paper (or chisel, pocket knife, lath or beaver teeth) to reduce the diameter on one end of the Upper Section and Lower Section dowels to match the inside contour of the female copper fittings. The dowel ends should insert to the bottom of the threads on the female fittings.
Both ends of the Middle Section dowel should be reduced to fit the male copper fitting. This dowel should insert all the way to the end of the male cooper fittings. (The male fitting requires the dowel to have two step diameter reduction in order for the dowel to fit flush to the end of the fitting.)
Reference the last photo in this series.
2: Test fit the dowel in the copper fittings several times as you are reducing the dowel diameter. The dowel needs to press tightly into the fitting. Use a mallet to force the fittings on (be careful to not damage the threads.)
Note: The fitting will ultimately have to be removed to apply the adhesive. This is where the wrench flats on the fitting come in handy. Use them to twist off the fitting.
3: Remove the fittings and “roughen-up” the inside of the fitting with something sharp (like the bent point of a nail or a file.) The deeper the gouges / scores on the inside of the fitting the better the adhesive has something to grip onto.
4: Similarly,“roughen-up” the end of the wood dowel by making grooves to hold the adhesive.
5: Mix the adhesive per the package instructions. Protect the threads on the fitting with tape. Apply adhesive to the inside of the fittings, and the ends of the dowels. - Make sure adhesive does not get on the threads.
6: Pound the fittings on the dowel ends and clean-up any adhesive that oozes out. Again, make sure the threads are free of adhesive.
Step 3: Drill Seat Pin Holes
Drill holes in the end of the dowels. This is required to accept the pins on the canvas seat.
1. Drill a 3/16" hole 2" deep into the center of the dowels at the fittings on the Upper Section and Lower Section .
2. Drill a hole in only one end of the Middle Section.
Step 4: Add Pivot Notches
Pivot Material:
(1) 2" inner diameter welded chrome ring. (Typically found in the hardware store near the chains.)
This is the Pivot Ring (reference the last photo in this series) it holds the center of the dowel sections allowing them to flare out.
Two notches are required In the center of each dowel section to accept the Pivot Ring.
1. Make the the first notch perpendicular, straight across the dowel. (I used a file to make the notch)
2. File the second notch at a 30 degree angle.
The notches should be about 1/4" wide and 3/8" deep.
the perpendicular notch is for the initial positioning of the dowels when they are loaded into the Pivot Ring. The angled notch accommodates the splayed position of the legs when forming a tripod.
Step 5: Sew the Canvas Seat
Seat Materials:
(2) Pieces heavy canvas (approximately 14"x14")
Heavy duty Polyester thread
1: Cut two pieces of canvas into triangles (14" per side)
2: Sew the two pieces together along the three sides. Stop the sew lines about 2 inches short on each end
3: Turn the sewn together pieces of fabric inside-out through one of the openings at a corner of the triangle .
4: Fold over each edge of the triangle to a width of about 3/4 inch and sew. This will form a "sleeve" along each side of the triangle.
Step 6: Thread the Cable
Reinforcement Material:
1/8" Stainless Steel Cable (Approximately 24" in length)
(1) 1/8" Aluminum double Ferrule (reference last photo in this series)
(3) 2" long Stainless Steel Cotter Pins
1: Thread the cable through the "sleeves" in the seat fabric. The cable holds the top of the dowel sections in position preventing them from over splaying.
2: insert the ends of the cable into the ferrule and crimp. A 5lb sledge hammer worked well to compress the ferrule.
3: Open the three cotter pins and load over the cable at the tree corners of the triangle. These are the Seat Pins used to attach the seat fabric to the dowel sections.
(The open legs of the pin act like a spring to hold them in the dowel holes.)
Step 7: Assemble the Seat
Load the Upper Section, Lower Section and Middle Section through the Pivot Ring.
Make sure the ring is in the notch of each section as the next section is loaded.
Step 8: Form the Tripod
Rotate each dowel section in the same direction so that the Pivot ring aligns with the 30 degree notch in each dowel section.
The splayed dowels will form tripod legs.
Step 9: Insert the Seat Pins
Insert each of the three Seat Pins into the holes in the dowel sections
Step 10: Seat Complete
This is the seat fully assembled, and ready to go...actually ready to stay.
I created a logo for our Boy Scout Troop using a graphics program and printed it out on iron-on transfer paper. (this paper is readily available at any office supply store.) It bonded well to the cotton canvas fabric. (Remember that any iron-on transfer needs to be printed in reverse.)
Step 11: Seat in Action
The seat is sturdy enough to hold a decent sized adult. It is as comfortable as any tripod camp stool can be, but it serves its purpose well for a trail side break.
Now if only it reclined and had a foot rest....
Below you can see the Hiking Staff Seat in conjunction with the light weight Backpacking Table described in the following Instructable: https://www.instructables.com/id/Camp-Table-for-Backpacking/
6 People Made This Project!
- Erfunden made it!
- Blue Hawaii made it!
- RickG5 made it!
- Ranasp made it!
See 2 More
130 Comments
Question 3 years ago on Step 2
I am at my witt's end. I have searched for these copper fittings but cannot find them. My 3 sons are all born in August and I wanted to make one for each of them and myself. Where can I find them? Is there a specific store/supplier and a specific name for them?
Answer 2 years ago
Hi there, I was able to find them at my local Home Depot. Perhaps if yours doesn't have it in store, you can order it online from them.
6 years ago
Elkhart #30500 1/2x6 COP Air Chamber
Amazon
Reply 3 years ago
I used a 3/4" Anti Hammer Air Chamber found at Lowe's. Most expensive part of the whole build.
4 years ago
very useful outdoors, very cool
6 years ago
Very cool! I plan on making one for myself and scaled down ones for the 2 boys ( aged 9 and 10) that I spend time with hiking and camping.
Reply 6 years ago
I looked at using PVC, but there is quite a difference between the hole of the cooper and the outside of the PVC. So there has to be a lot of glue or, there has to be a lot of material taken from the PVC to fit. How did you handle that?
6 years ago
Would have been more functional it you included a spear head that could thread into the top connector, maybe even a three prong trident for fishing, or don't boy scouts do that kind of think anymore?
8 years ago on Introduction
Very very cool! I have been looking at putting together a hiking staff. For me it has to have two main things it does well. It has to work well for walking and for self defense. I like the idea of a multi functional staff, but wasn't sure how to do that without compromising the defensive part of the staff. Your copper fitting idea might just do the trick. The staff should be sturdy enough to not break when you hit something. Also, the copper fittings on the end should increase it's effectiveness as a defensive tool. I am thinking of getting a 6 foot bo staff and using that.
Reply 6 years ago
I'm looking at this as self-defence as well. I have a fishing hole that I share with a family of beavers and some geese. About twice a year I have a problem with the males getting overly dominant. Having 6-feet of stout oak between me and an angry goose has a certain appeal.
6 years ago
What does this staff (Oak, 6' high) weigh? Has anyone tried using bamboo? Bamboo's lightweight, surprisingly strong, and used in temporary scaffolding for building construction in Asia. You'd have to pick through a bunch to match fittings. thediameter with the copper
Reply 6 years ago
You may want too consider rattan if you wanted to stick to asian materials
Reply 6 years ago
Pretty sure bamboo is hollow, no? So I'd think it would be a major weak spot @ the point of attachment of the fittings. Also: The diameter isn't as consistent as milled dowling, thus you won't end up with as good of a fit and finish.
Reply 6 years ago
Yes, bamboo is hollow over the longer sections of its length. There are nodes containing short, solid cross-bridges. I don't know how strong it is; probably weaker than solid oak, but is that enough? That's why I mentioned the scaffolding. As for the tips, you might have to glue the in place with epoxy. Best way to find out, of course, is to build one and test it.
6 years ago
Hi. You might have answered this already: Is there an important reason for the connectors to be made of copper vs. some other material?
7 years ago on Introduction
I like this. But on Step 4 you make no mention of how high up the poles the notches should be placed.
Reply 6 years ago
it said halfway up each dowel
6 years ago
what is the piece at the top of the staff? Is it just some personalization or something necessary? Sorry if I missed that in the instructable.
6 years ago
I love this instructable.
I've used this approach to make several staffs for myself (and a couple for my sons, who helped with theirs) that we can break down and store in our bags with the rest of our martial arts gear. This has given us highly-portable versions of a bo/jo for use in practice, and can also serve (in their "broken down" form) as backup weapons for stick fighting classes. (I'm generally reluctant to use them for "contact" fighting drills, given the brass fittings, but have done so on occasion.)
6 years ago
Thanks for the great Instructable!!
I'm planning on making one of these over these next few weekends, with some modifications:
· I hope to use paracord as the seat support; several lines around the outer triangle will serve as a framework for weaving a net. The net should provide extra support under the canvas (I'm a big boy). I still need to figure out how to protect the paracord lines at the corners from the cotter pins - maybe a plastic sheath at those points?
· I'll also use paracord instead of the ring, either a simple wrap several times around with a clove hitch to secure, or a full-out tripod lashing.
· I'm installing male connectors at top and bottom.
· I found an iron cap in the plumbing section that fits the male connector - it looks sturdy. I'll install that on the bottom to take the repetitive impact when hiking.
I'll try to remember to take pics of the differences, and will update the post once completed to let everyone know how it works. If it works well, it will go with me to the Boundary Waters Canoe Area this spring, and to Devil's Den State Park in the summer. It will then be a regular part of my backpacking gear!
Peace and Long Life,
Twonster
