Introduction: Multi Position PCB Clamp
This is a 3D printed clamp for clamping PCB boards with a max width of 72mm, and a max length of 150mm. I will design other clamps for wider boards. The clamps rotate 90 degrees as shown in pictures.
Tools:
- Soldering Iron
- 3D printer
- M4 Allen Wrench
Materials:
- 3D printed parts (https://www.thingiverse.com/thing:6538677)
- x6 M4 brass threaded inserts (These are a good buy. If you don't use those, make sure that your inserts have an O.D. of 5.4mm and are no longer than 4mm)
- x2 M4 Hex Nut
- x2 M4x12 Socket head cap screw
- x4 M4x16 Socket head cap screw
- x2 M4x10 Socket head cap screw
Step 1: Press in Inserts
Use a heated soldering iron to press in your inserts as shown in the above picture. After pressing, you may want to make sure that there is no plastic build up blocking the holes.
Step 2: Assemble the Base
Next, slide 2 M4 nuts into the slots of the Base and align the End Bracket's mounting holes over the nuts. Use the 2 M4x12 screws to fasten the End Bracket onto the Base, but don't tighten them all the way.
Step 3: Mount the Clamps
Now slide the Clamp Part 1 pieces onto the End Bracket and the Base. Use 2 M4x10 screws to lock them into position.
After that, align the Clamp Part 2 pieces with the holes for them on the Clamp Part 1 pieces and tighten enough to where you can slide a PCB board between them.
Step 4: Finished!
Thank you for reading this Instructable! If you have any Questions, Comments, or future project ideas, I would love to hear them.
