Introduction: Multi Purpose Container
This fun Easter project is made from reused crystal light containers. It's a super easy project that really gives that Easter touch. And this fun craft can be used for so many things like in this picture where it was used for silverware. Although it can be used for so much more such as school supply holder, condiments, craft storage, anything laying around that you want to look organized, and so much more. So let's get started.
Step 1: Gluing
So for this easy step all you need to do is simply glue the containers together with hot glue. Or you can try any type of glue you have laying around. And you can glue them in any shape whether you want it such as horizontal or you can just do it in a set of 4 like how I did in the project. And depending on how many containers you have you can make this storage as big as you want.
Step 2: Crochet
So for this project you are going to need to know a little bit of crochet knowledge. So what I did for this, was I single crocheted 51 then turned and did 4 rows. And once you have done that you just connect the two ends together and fit it over your plastic containers. And then use a crochet needle to hide in the ends.
Step 3: Handle
Now you crochet a handle. so I did 46 single crochet then did only three rows. Then I connected each end to part of the other section we previously crocheted. And you can make this handle however long or short you want it. And you can connect it to the top of the section we previously crocheted or the bottom. And for this project I connected it on the bottom and the top because I found it to be more secure.
Step 4: Done!
Congratulations now you are done with this fun project and can display it for all to see, whether your using it for a barbeque, just purely decoration, on your table, or whatever else you want. Enjoy.
