Introduction: Multi Triggered Adapter for Router
This circuit will work when lights gone or for emergency. Let me explain you when you connect your router on a main supply we use internet suddenly! lights gone and we need internet and now, what we do? then this circuit was very helpful we can continue your work easily because when lights gone it was work on battery or in other words router gives a power from battery.
Step 1: Components
Multi triggered adapter for router
you will need
Resistor
- 1k (1)
- 220k (1)
- 5 watt 15 ohm (1)
Capacitors
- 100uf, 25 volt (1)
- 10uf, 25 volt (1)
- 100nf, 63 or 100 volt (1)
- 225 joule, 400 volt (1)
Diodes
- IN4007 (5)
- IN5400 or b/w IN5408 (2)
7809 regulator (1)
12 volt dc relay (1)
led (red)
12 volt router adapter and router
solar controller
12 volt 7 amp battery
soldering iron and solder
wires
Step 2: Diagram
follow the diagram and then assemble it be careful make sure everything available.
Soldering all components according to diagram.
Step 3: Solar and Controller
according to diagram which one on previous slide the wires from solar and a battery on a controller.
Step 4: Complete
Then its look like this. After all of these now you connect the all things pin on a router, battery pins on a battery, adapter and circuit switch on 220 volt.
Its really cool.
Thanks for watching............;)
