Introduction: Multifunction Coffe Table With Storage, Slide Out and Lift. Build From Euro Pallets
This coffee table was Born while we were searching all over for a new table for our living room. Nothing fits in form and function. So we build our own.
Made of 2 europallets. Movable on 4 heavy duty castors.
The highlight is the huge storage space inside the table and the lift and the slide mechanism.
On the outside, the table has many small compartments for storage.
Inside is a huge storage room for games, craft, other things. You even can accommodate 3 tool boxes and stowed invisible.
To open one side of the table it can be easily pushed to the side to slide it out. capacitiy in the extened state is 60kg! If the table is closed you can load more than 600kg.
Here you can now work or play. Now you also have access to the stowed stuff inside the table.
The other side can be easily lifted up with 2 fingers due to a hoisting mechanism supported by two gas springs.
Half of the table now moves beyond 17 cm over the edge to the side and lifts up about 20 cm. Perfect height dining table in the living room for the couch.
All decoration or everyday objects can remain on the table.
This Coffee table is now one of the challenger in the Woodworker Contest. Would be nice if you vote for me if you like that table.
Greez,
Dirk
You Need:
Tools:
Cordless Screwdriver
chop saw
sander
planer
Remove pliers or angle grinder for nails
Optional: Drill with 3-4 mm drill bit for pre-drilling before screwing . Depending on how dry or brittle wood is .
Material:
2 pallets
and also some boards with the same thickness as the boards of the pallet .
I recommend this because you have the better surface for the table top.
or you need at least 3 pallets and you used the wood of the third range .
2 heavy- duty slides
for the sliding mechanism. Heavy duty is recomended so you can put weight on it while it is extended . With normal drawers extracts there is a danger that if someone is put some weight on it when the plate is extended , this will break .
A lifting mechanism.
I took the Tavoflex from Häfele . Is similar to the one from woodworkers . Look in the comments.
DIY is also possible. Look my other table.
Many screws
1.
Remove the red marked boards from pallet number one.
Cut the cross running board at the red lines.
Close the bottom of pallet one with some wooden boards that are left or buy some new wooden boards to close the bottom.
Now you have something like a wooden box. Just the 2 open compartments on each side.
Close this 8 compartments with some small wooden boards.
Put 4 wheels on the four corners. Pallet number one is finished so far.
2.
Disassemble pallet number two.
We need 2 smal assys consisting of Number 4, 5, 6 and 9. (see attached Pic in the overview)
This two assys are screwed on pallet number one.
From part 10 (2 each) and 1 (2 each) we build aframe similar to the shape it got before disassemble the pallet.
Now we screw this frame to the top of our construct.
Woodworking Contest
31 Comments
1 year ago
hi, did you ever manage to make a more in detail guide?
Tip 3 years ago on Introduction
Hi Dirk,
Greetings, That's an amazing piece, Do you have a video to do it my self or more detailed instructions? if you have please email it to
tonygripo@gmail.com
I really love what you've done its truly something to be proud of keep up passing on the ideas I'm new to the wood working world and could use all the help i can get
Thanx for sharing
Tony
Question 4 years ago on Introduction
Bonjour pourriez vous m'envoyer les photos des différentes étapes de la construction ma fille aimerait bien que lui fabrique cette table.
mail:vanle.chris@gmail.com
merci d'avance
5 years ago
hello! do you have a picture where one can see how height is the table in relation to the sofa? or dimensions when lifted? i´m not sure i i´d have to add one more EURO
5 years ago
On ebay the brackets $45.
7 years ago
how much are the brackets? look expensive. where do you source them from ?
Reply 7 years ago
I went to Hafele's site, linked further down in the comments, and they wouldnt even sell me the part unless i was a commercial customer. It was also $105.30 for a pair of the brackets. I'm opting to build my own brackets and putting the entire process on instructables starting with pistons from homedepot.
http://www.homedepot.com/p/Richelieu-Hardware-Pneumatic-Lift-System-12-kg-BP57812105/202215984?cm_mmc=Shopping|THD|G|0|G-BASE-PLA|&gclid=CNDr-vaIlskCFU47gQodQooMkA&gclsrc=aw.ds
Reply 6 years ago
had the same problem here in the UK tried to source in the USA, But postage too expensive.
Reply 6 years ago
Why not just take a day to do your research and walk into some hardware stores? Im pretty sure you could find something usable for a much cheaoer price! I hope it works out for you, post pix if you do try making your own brackets! Would love to see!!!!!
6 years ago
Hi Dirk,
Greetings, That's an amazing piece, Do you have a video to do it my self or more detailed instructions? if you have please email it to me on: salem@grome.com
7 years ago
Nice table
7 years ago on Introduction
I'm sorry but I can't vote for anything that isn't complete, there are written steps and pictures missing
7 years ago
Hi im new to this site, can anyone tell me why i cant see all the instrutions for this table?
Thanks
Here a link to the lifting mechanism:
DE: http://www.haefele.de/product/hebebeschl-tavoflex...
EN: http://easylink.hafele.com/is-bin/INTERSHOP.enfin...
There are different version im not shure which one has been used in the instructable, verify yourself!
8 years ago on Introduction
Hi I really love the table you made. Is there a video to show you how to put it together?
Hi ! Really cool table ! I really want to do a same thing for my home ! I have a question ! Where did you buy this component : https://cdn.instructables.com/F78/V7CY/HS9YA25T/F78V7CYHS9YA25T.LARGE.jpg Thks you !
so what are these hinges called again?
Reply 8 years ago
I added some parts in the description.
Reply 8 years ago
you can find it there.
Thank you for your comment. You're so right. And as I have already written in the text, I'll include the exact instructions yet.
Best regards,
Dirk
