Introduction: Multiple Blinking LED on the Arduino
In this tutorial I will show you how to make multiple LEDs blink with Arduino. You will need three LEDs, jumper wires, breadboard, and Arduino.
Step 1: Program the Arduino
Now you will need to paste the following code into the Arduino software and upload it to the Arduino.
int led = 13;
int led2 = 12;
int led3 = 11;
// the setup routine runs once when you press reset:
void setup() {
// initialize the digital pin as an output.
pinMode(led, OUTPUT);
pinMode(led2, OUTPUT);
pinMode(led3, OUTPUT);
// the loop routine runs over and over again forever:
void loop() {
digitalWrite(led, HIGH); // turn the LED on (HIGH is the voltage level)
delay(100); // wait for a second
digitalWrite(led, LOW); // turn the LED off by making the voltage LOW
delay(100);
{digitalWrite(led2, HIGH);
delay(100);
digitalWrite(led2, LOW);
delay(100);}
{digitalWrite(led3, HIGH);
delay(100);
digitalWrite(led3, LOW);
delay(100);}// wait for a second
int led = 13;
int led2 = 12;
int led3 = 11;
void setup() {
void loop() {
delay(100);
delay(100);
delay(100);}
delay(100);
Step 2: Connecting GND
First connect a jumper wire from GND to the negative rail on the breadboard.
Step 3: Connecting the LEDs.
Then plug in the other jumper wires like this:
First, plug a wire from 13 on the Arduino to the top row on the breadboard.
Next, plug a wire from 12 on the Arduino to the top row on the breadboard.
Then plug a wire from 11 on the Arduino to the top row on the breadboard.
Space these out well. Use the picture to help you.
Now connect a wire going from the negative rail to the right of the other wires on the breadboard.
Lastly, put the longer leg of the Led (+) under the wire that goes to the Arduino. The shorter leg of the LED goes under the port that connects to the negative rail.
