Introduction: Multiple Ultrasonic Sensor Using Single Arduino
Abstract :
In this project, I am controlling 5 LEDs and 5 ultrasonic sensors using a single Arduino board. each sensor is pointed to a particular led and all 5 LEDs maintain their state for a particular period of time.
The purpose of this project is to get distance data from multiple sensors simultaneously and using this data to control LEDs.
Components Required:
Step 1: Wiring and Schematic
I am using an ultrasonic sensor in single-wire mode.
using only one wire for trigger and echo
Ultrasonic Sensor 1,2,3,4,5
US1-----Echo------Trigger = Signal 1 (Short Both echo and trigger of 1 ultrasonic sensor)
US2-----Echo-------Trigger = Signal 2
US3-----Echo-------Trigger = Signal 3
US4-----Echo-------Trigger = Signal 4
US5-----Echo-------Trigger= Signal 5
Arduino----------HC-SR04
Pin 8------------US1 = Signal 1 = Echo1+Trigger1
Pin 9------------US2 = Signal 2 = Echo2+Trigger2
Pin 10----------US3 = Signal 3 = Echo3+Trigger3
Pin 11----------US4 = Signal 4 = Echo4+Trigger4
Pin 12----------US5 = Signal 5 = Echo5+Trigger5
5v---------------US 1,2,3,4,5 (5V)
GND-----------US 1,2,3,4,5 (GND)
Arduino------------LEDs
pin3------------------LED1
pin4------------------LED2
pin5------------------LED3
pin6------------------LED4
pin7------------------LED5
GND----------------LED GND
Step 2: Code and Working
The main heart of this project is the new ping library.= Download Library from here
Code = Download code from here
This Code doesn't use any delays and is event-driven.
You can think of it as multitasking.
void loop() {
for (uint8_t i = 0; i < SONAR_NUM; i++) { // Loop through all the sensors.
if (millis() >= pingTimer[i]) { // Is it this sensor's time to ping?
pingTimer[i] += PING_INTERVAL * SONAR_NUM; // Set next time this sensor will be pinged.
if (i == 0 && currentSensor == SONAR_NUM - 1)
oneSensorCycle(); // Sensor ping cycle complete, do something with the results.
led (); //Turn ON the LEDs according to State.
if((millis() >= time_now + period) && (led1State == HIGH || led2State == HIGH || led3State == HIGH || led4State == HIGH || led5State == HIGH ) ){//15s delay using millis function and it only starts when any one LED is ON.
time_now = millis();
/*after 15s set, all LEDs state to LOW.*/
led1State = LOW;
led2State = LOW;
led3State = LOW;
led4State = LOW;
led5State = LOW;
sonar[currentSensor].timer_stop(); // Make sure previous timer is canceled before starting a new ping (insurance).
currentSensor = i; // Sensor being accessed.
cm[currentSensor] = 0; // Make distance zero in case there's no ping echo for this sensor.
sonar[currentSensor].ping_timer(echoCheck); // Do the ping (processing continues, interrupt will call echoCheck to look for echo).
}for (uint8_t i = 0; i < SONAR_NUM; i++) { // Loop through all the sensors.for() loop in void loop() polls each sensor array waiting for when it's that sensor's time to ping.
void echoCheck()
{ // If ping received, set the sensor distance to array.
if (sonar[currentSensor].check_timer())
cm[currentSensor] = sonar[currentSensor].ping_result / US_ROUNDTRIP_CM;
echoCheck() is where the background ping is polled every 24uS to see if ping was received, it sets the ping distance in CM in the cm array.
oneSensorCycle() uses the distance data collected from different sensors to turn ON-OFF the LEDs.
void oneSensorCycle() { // Sensor ping cycle complete, do something with the results.
/*Store sensor data in Array*/
sensors[i] = cm[i];
/*LED Logic Start Using if Statemet*/
if (sensors[0] > 0 && sensors[0] <= dis)
led1State = HIGH;
if (sensors[1] > 0 && sensors[1] <= dis)
led2State = HIGH;
if (sensors[2] > 0 && sensors[2] <= dis)
led3State = HIGH;
if (sensors[3] > 0 && sensors[3] <= dis)
led4State = HIGH;
if (sensors[4] > 0 && sensors[4] <= dis)
led5State = HIGH;
if ((sensors[0] > 0 && sensors[0] <= dis) && (sensors[1] > 0 && sensors[1] <= dis))
led1State = HIGH;
led2State = HIGH;
if ((sensors[1] > 0 && sensors[1] <= dis) && (sensors[2] > 0 && sensors[2] <= dis))
led2State = HIGH;
led3State = HIGH;
if ((sensors[2] > 0 && sensors[2] <= dis) && (sensors[3] > 0 && sensors[3] <= dis))
led3State = HIGH;
led4State = HIGH;
if ((sensors[3] > 0 && sensors[3] <= dis) && (sensors[4] > 0 && sensors[4] <= dis))
led4State = HIGH;
led5State = HIGH;
if ((sensors[4] > 0 && sensors[4] <= dis) && (sensors[0] > 0 && sensors[0] <= dis))
led1State = HIGH;
led5State = HIGH;
}The Block diagram of this LEDs logic is shown above.
led1State = LOW;
led2State = LOW;
led3State = LOW;
led4State = LOW;
led5State = LOW;
}Turn OFF the LEDs after 15 Seconds using millis() function.
