Introduction: Multipurpose Bone Maori Hook Pendant /Pot Hanger
A weeks ago I saw on Instagram a hack that blew my mind and I decided to give it a go and try it by myself. It would be great if You could use some garment or accesories in some more usefull way. Here we go !
Es genial estar de nuevo en instructables esta vez quiero compartir con uds un hack que vi en un post de instagram y decidi hacer mi propia version, que mejor que utilizar un accesorio de decoracion como algo utilitario que me ayude en una de los hobbies que mas me apasiona El camping
Gathered Dry Cow bones
Motortool
Motortool bits
Rough sand
Jéwelry Files
Hacksaw
Grinder
Step 1: Gather and Cut Some Dry Bones
In some or My walking trips I have found some Dry Cow bones pieces buried in the ground. So I have gathered some pieces. Bones has been used since the beggining of time for tools and accesories. What I needed for this proyect is a flat piece of bone. I choose a Dry piece and cutted it in three pieces, flatting the Surface with sand paper unti it was completely flat. its about 5 x 30 x 50 mms.
Step 2: Carving the The Bone
Once I had the flat piece I drew some Maori hook style design, drill two holes and start to cut out with a hack saw. Then with the motor tool, I choose the proper drill bits to soften their edges and make a smooth look. You can also use think sandpaper and jewelry files to improve the design.
Step 3: Let's Make Some Coffee
Now that is finished I can use it as a pendant, or a carabiner hook also resist a lot of heat when It is used as pot holder...its so cool when You can carry some handmade gadgets.
Step 4: Wear It Proudly
I hope You liked it and try your own versión. There is a Lot of possibilities You can use this hook.
