Introduction: Mural W Shape Library
I like books about design, architecture, Diy, and I have now a lot of them but they are spread in different places and since I do not see them I do not read them often.
After my chidren left home, I decided to use one of the rooms and I thought it was an opportunity to collect my books and have them available.
I decided to make a library a little original and makes best use of the available wall.
I started to draw some sketches, and chosed one project: W shape library, decided dimensions, and I defined the materials needed
I presented the project on my Web Site in French:
Step 1: Cut the Pieces
The cuts are easy thanks to the miter saw.
Step 2: Preparing the Grooves
For the assembly, I used a new technique for me, biscuit joints. I bought a cheap biscuit jointer at Lidl.
The grooves milling is a little long to do but this allows to have solid connections because the lamella allows a shear and discrete connection. I managed to master the bicuit jointer, but you have to think and be methodical to keep the reference face.
Step 3: Assembly, Bonding
For assembly, you have to think about the sequence, be fast enough, and have enough clamps.... In the end it went well and the links are quite clean.
Step 4: Metal Reinforcements
Even if I have confidence in the collage, as books are heavy, I reinforced the connections with squares, or tees metal plates.
To fix the shelf on the wall, I used sheet metal corners, which I drilled to put several screws.
I have installed a corner in each box to distribute the effort on the plaster wall which is not very strong.
Step 5: Varnish
For the varnish, my wife is better than me and she took the job.
Step 6: Installation
With some ... books...under the furniture I could have installed the library alone, but Jeremie the older son and by the way former occupant of the room helped me.
Well, it’s fixed, and solid, I think it fits the wall quite well.
Ready to fill it.
