Introduction: Mushroom Rice
I made this wonderful mushroom rice as dinner for my family. this serves 3 people, so adjust the quantities for how many people you are cooking for. Could serve more as a side dish to another meal.
It happens to be vegan, even though I'm not, so it's fully enjoyable for vegans and meat eaters.
It's special because the mushrooms are cooked twice to enhance the flavour.
200g Mushrooms (7 ounces)
200g basmati rice ( 7 ounces)
1 small onion
1 spring onion (scallion/green onion)
Spinach
1 vegetable stock cube
salt
garlic powder
Vegetable oil
Turmeric
Non stick frying pan
Steel Sauce pan
Step 1: Chop and Dry-fry Mushrooms
Peel your mushrooms, and chop them into quarters or eighths. the shape or size is not actually important, it depends on your preference. I prefer them quite big so I quarter them, (remember, they will shrink in the process of cooking)
Save around a handful of the chopped mushroom pieces in a bowl, and put the rest of them in a non-stick pan on a low-medium heat. Don't put any oil or water in at this stage. You will start to see steam coming off the mushrooms, and hear a sizzling sound.
(This stage is important because drawing the moisture out of the mushrooms really enhances the flavour.)
Once the mushrooms are cooked (they will appear more dark and shinier, see photos) pour the contents of the frying pan into a separate bowl. (including any liquid)
Step 2: Cook the Rice
rinse 200g rice a few times by sieving it and putting it under the tap.
Add it to the steel saucepan. Add enough water to double the height of the contents. (e.g, if the rice is 1cm tall in the pan, the water+rice should be a total of 2cm tall in the pan.)
put the rice on the stove on high heat. and add the vegetable stock cube, half a teaspoon of salt, a heaped teaspoon of garlic powder, and one teaspoon of turmeric.
Bring to a boil.
Add the handful of uncooked mushrooms you saved from earlier into the pan and stir.
Leave the rice on high heat until all the water has disappeared, then, turn the stove down to the lowest heat, and cover up with the lid.
Leave this for 10 minutes and then turn off the heat. the rice will be fully cooked.
Step 3: Re-cook the Mushrooms
Finely chop a small onion, or half of a medium onion.
Fry add 2-3 spoons of vegetable oil of your choice to the frying pan, fry on a medium heat.
After about 5-7 minutes or when the onions have softened, add the mushrooms back in. you'll see some black liquid in the bowl, this is water from the mushrooms, add this back in too.
wash some spinach, however much you want and add this to the pan. this will shrink by a lot.
Add a small pinch of salt and a small pinch of garlic powder
This step is complete when the spinach has shrunk.
Step 4: Mix Everything Together
Add the all the mushroom/spinach/onion into the pan with the cooked rice.
there should be a some liquid from the mushrooms. Mix thoroughly, until the rice has slightly darkened.
Optionally, cut up a spring onion into small pieces and sprinke on top.
This is now ready to serve, you can eat it as is, or as a side dish. You can also sprinkle some Garam Masala Spice
