Music Visualizer With Arduino
Introduction: Music Visualizer With Arduino
Interactive Music Visualizer
Components
LM338T x5
Potentiometer x2 (1k and 10k)
1N4006 diode x5
Capacitor x2 (1uF and 10uF)
Resistors x3 (416, 10k and 1k)
Aux splitter x1
Aux cable x1
Arduino Duemilanove x1(Uno tested okay)
Aux jack x1
LM785C x1
TL071CP x1
9V battery jack x2
Jumper cable x Many
LED with WS2812B controller x46
Dell 16V 20A laptop adapter x1
Step 1: Soldering 5 LM338T Arrary
This linear voltage converter array steps down 16V laptop adapter supply voltage to 5V LED supply voltage.
Step 2: Pre-processing Circuit for Aux Signal Input
On the left hand side of the breadboard is TL071 op-amp circuit which sums and amplifies aux input signal that ranges from -1.25 to 1.25V. Signal is shifted to Arduino Vref 0~5V during pre-processing stage. It blocks out the noise generated by Arduino analogread() operation. LM7805 voltage regulator is located in the center of the breadboard, which converts 9V battery supply voltage to 5V supply voltage for Arduino. Aux-in jack is on the right side edge, ensuring good connection with playback device. The aux splitter slips playback device output signal into two. One is supplied to speaker, another is supplied to Arduino.
Step 3: Arduino Pinout and LEDs
On the lower side of the Aruidno board, Aruidno is grounded to breadboard by the white wire on the left, pin2 reads audio output signal from pre-processing circuit. On the upper side, Arduino is grounded to LM338 array by the other white wire, pin3 on the right side feeds serial signal to LED strip.
Step 4: Result
Step 5: Source Code
Be the First to Share
    • Tinkercad to Fusion 360 Challenge
    • Pets Challenge
      Pets Challenge
