My 24p WiFi Booster
Intro: My 24p WiFi Booster
Hi all, I know that this has been done many times before, but I just thought I'd post it as I bothered to take photos of it :P
It only cost me 24p (UK) per antenna for this project, so it is nice and cheap.
My router is a Tenda model, which already has 2 aerials and a dish and only cost me £25, so I would really recommend it.
STEP 1: Materials
Heres what you need:
A Wire Skimmer (for taking food out of pans)
Pliers
Spare Aerial or stick the same diameter as your aerial
Any other metal strainer/sieve should work to :)
Pliers
STEP 2: Removing the Handle
Just look at how the metal dish is attached to the handle, and either pull it off or unbend the wire (I did that in my case) so you just have the dishes.
Do as many as you need, some routers have 3 or more, so make sure you have enough
STEP 3: Attaching to the Aerial
This will depend on how the dish was attached to the handle, in my case, I was able to bend the wire again around the aerial so that it held tight, I also poked the tip of the aerial through the mesh, and it won't slip now.
If there is no wire to attach to, you can either use hot-melt glue to attach the dish, although you can't take it off or reposition it; or you can attach extra wire to the dish (maybe with glue again) and then bend those into shape.
Make sure the aerial do not slip, as reception could drop annoyingly.
STEP 4: Finished
Here you go, now that you have it up, go and check your reception, it should change quite a bit hopefully.
Enjoy
Enjoy
4 Comments
sn00ze 14 years ago
It would work in a similar way to a parabolic reflectors.
falcotheimpaler 14 years ago
lhd 15 years ago
Coggz 15 years ago
