Introduction: My First Chicken-Fried Steak
What is "chicken-fried" anyway? According to the never-wrong Internet, "chicken-fried" refers to something breaded and fried. By this definition, Wiener Schnitzel is chicken-fried veal, and a Filet-o-Fish is chicken-fried American processed seafood product. Why am I doing something chicken-fried now? Because the local Kroger big-box store had clearance-priced cube steak and I have a recipe for chicken-fried cube steak. Therefore, I made the recipe!
As always, the recipe picture above is a 4x6 JPG. You can download it and print it on 4x6 photo paper to keep in your personal recipe box.
For equipment, you will need:
- A heavy 12" skillet {Amazon affiliate link}
- A whisk safe to use on your pans and with hot oil {Amazon affiliate link}
- Tongs safe to use on your pans and with hot oil {Amazon affiliate link}
- Various measuring cups and spoons {Amazon affiliate link for cups; spoons used no longer available}
- A mixing bowl {Amazon affiliate link}
- A rimmed plate or shallow bowl (from Dollar Tree)
- Another plate lined with paper towels (from Dollar Tree)
- A large baking sheet to hold the steaks while they rest (from Kroger)
- A small saucepan at least 1 quart {Amazon affiliate link}
- A clean kitchen towel {Amazon affiliate link}
- Heat source (I used a stovetop)
For ingredients, you will need:
- 240g all-purpose flour, divided
- 2 tsp. baking powder
- ¾ tsp. salt
- ¾ tsp. onion powder
- ¾ tsp. garlic powder
- ¾ tsp. chili powder
- ¾ tsp. pepper
- 1 large egg, lightly beaten
- 1¼ cups buttermilk, divided
- 4 beef cubed steaks (4 oz. each)
- Oil for frying (about 3 cups?)
- 1½ cups 2% milk
Step 1: Mix Dry Ingredients
- Weigh 210 grams of all-purpose flour (I use unbleached) into the mixing bowl.
- Whisk in the baking powder and all the seasonings.
- Pour the mixture onto a rimmed plate or shallow bowl.
Step 2: Mix Wet Ingredients
- Wipe down the mixing bowl and whisk with the clean towel.
- Into the mixing bowl, combine the egg and the buttermilk.
- Whisk until well combined.
Step 3: Coat
- Dip a steak into the bowl of wet ingredients.
- Roll it in the dry ingredients on the plate.
- Place the dipped steak on the baking sheet to rest.
- Repeat this step with all four steaks.
Step 4: Heat Oil
- Place skillet on heat source.
- Pour oil into skillet.
- Your volume of oil may vary. In my 12" skillet, I needed about 3 cups of oil to reach the proper depth. The important thing is to have at least ½" of depth.
- Turn on heat source to medium-high
- 6 on my gas stovetop
Step 5: Meanwhile, Measure Other Ingredients
- Weigh 30g of all-purpose flour in the small saucepan
- Measure the 2% milk
- Measure the remaining buttermilk
- I used a 2-cup measure to have the milks all in the same place.
Step 6: Fry & Drain
- By now, the oil should be shimmering. (Unfortunately, that is not easy to see on a photograph.)
- Put two steaks into the hot oil. (Only two fit this pan.)
- Cook 7 minutes on one side, flip using the tongs, and cook 5 minutes on the other side.
- Remove the steaks to the paper-towel-lined plate to drain.
- Repeat step for remaining two steaks.
Step 7: Start the Gravy
- Remove proper amount of drippings from skillet
- Pour this into the saucepan with the flour
- Whisk until smooth
Step 8: Finish the Gravy
- Place the saucepan on the heat source over medium heat
- Pour in the measured milks
- While whisking, bring the mixture to a boil
- Whisk, while boiling, until you reach desired thickness (or 2 minutes per the recipe)
Step 9: Voilà!
Pour the gravy on the steak and serve. And there you have it!
Step 10: Final Thoughts
Next time I make it, I might want to get the oil to a higher temperature before adding the steak. Only the edges are crispy. Also, the breading came out very dark. I may want to shorten the cooking time a little bit. Also also, this makes A LOT of gravy. I'd cut down the amount of ingredients used for the gravy, and I would make some potatoes to use up more of the gravy.
