Introduction: My Floating Home
I built this raft because I have always wanted a boat. I call it the party barge . It is about 4 and a half by 4 and a half .
Step 1: Frame
First you need to make the frame .you can make it to your specs but I like mine.
Take a 2x4 cut to the length you like then nail it or use screws . This part is pretty self explanatory but still. Repeat the step above until you have a strong square. Then add cross braces for support. I did mine to form a x in the middle. I don't have any pictures of building the raft . Just from after it was built .
Step 2: Deck
For the deck I used 1x6 . I nailed them down with 8d galvanized nails. I left a small space between each of the boards . Towards the back I nailed a 4x4 down and drilled a 1 and a half inch hole for rod and reel holders. Next I found some old reflectors and nailed them down . Safety first.
Step 3: Amenities
After I got the deck like I like it I made a small stove to go on it . To do this just drill some holes in the bottom of a coffee can . Under the stove I put a old license plate to keep it from catching fire. I then added a tiki torch for light and keep the mosquitos away . After that I made an anchor out of a bowling ball with a eye bolt in it . To make the rudder drill a hole in the 4x4 big enough for a pipe to fit snug then make a rudder and drill a hole in it to fit some what loose . Then put some 5 gallon buckets with a lid under it and enjoy .
