My Great Grandpa's Toolbox
Intro: My Great Grandpa's Toolbox
Every summer we would go over to my Great Grandpa's house out on his ranch and see what cool things he had. Unfortunetly he passed away in August of 2010. He had all these awesome compasses, hammers and all sorts of old tools that were fun to look at. We would really all just take a second and think, " Holy cow, tools have changed so much from 1890's to now". Actually just last week my cruddy cardboard toolbox (not really a toolbox) fell apart and I thought about building another one and, ta da, I was inspired to build an old-fashion toolbox in dedication to my Great Grandpa.
Warning: Tools are dangerous and don't forget to wear safety equipment.
STEP 1: Get Your Design Together
Base:
Length = 30 in
Width = 11 1/4 in
Long Side:
Length = 30 in
Width = 8 in
Short Side:
Tallest height = 15 in
Smaller height = 11 1/4 in
Width = 11 1/4 in
Set in tray:
Length = 29 7/8''
Width = 9 3/8''
Height = 2 1/2''
STEP 2: Materials
1 2"x12"x16' Southern Yellow Pine (treated)
1 1"x12"x6' Knotty Alder
(I didn't have the 1''x12'' so I used my bisciut jointer to make 2 boards equal the width I needed)
1 1 1/8"x32'' Stainless steel dowel
A box of 2 1/4'' Stainless steel screws
Wood glue
Wood stain
Clear coat
Crown staples
Tools
Skill saw
Miter saw
Table saw
Crown stapler
Screw gun
1'' butterfly bit
1 3/8 drill bit
Optinal
Sander
Router
Surface planer
Biscuit jointer
Good attitude
STEP 3: Cut and Plane Wood
Cut your material to the design lengths and prepare for assembly. The option of using your surface planer here will result in a more accurate finished product later.
STEP 4: Notch for Tray
STEP 5: Glue and Screw Pieces Together
STEP 6: Cutting and Inserting Handle
STEP 7: Routing the Edges
STEP 8: End Caps
You can make these out of scrap Knotty Alder if you have some or just out of any other board. The dimensions of this are up to you.
STEP 9: The Set in Tray
Note: The length of the short sides of the tray will determine the width of your base.
Note: The board with the handle cut into it is placed of center becaude of the fact that there is not enough space to put your hand in and pull the tray out.
91 Comments
Oysteinsa 7 years ago
JWaltLayne 8 years ago
Trike Lover 9 years ago
I've been mulling over making one or more toolboxes similar to this pattern - I still have one like this I made in Grade 7 wood shop class. My thought was to make the box a bit larger and beef up the joints, etc. This is a very nice project, and I thank you for sharing. Gotta get busy and go make some sawdust....
Grim Man 10 years ago
Now that's a really neat & inventive addition to what is already a very nicely executed and useful project. I was going to build a couple of these toolboxes, slightly customized for particular classes of tools (e.g. electrical, plumbing, general woodworing, etc., and now I'll add the bar clamp modification to each one.. I was also going to add a reinforced section in one corner to allow mounting a small clamp-on vise - this could also be made in such a way as to augment that. Many thanks for sharing.
Dr. Pepper 11 years ago
HunterBond 11 years ago
I'll be thinking of this and likely referring back when I finally get started on my own tool box.
Thanks.
average joe 1999 12 years ago
twhitfield 12 years ago
Dr. Pepper 12 years ago
sunshiine 12 years ago
Chumlee 12 years ago
its much bigger than i expected !! :D
