Introduction: Simple LED Switchie
Ok, let's make an LED Switchie!
(this is based off LED throwies from grafitti research lab)
You need:
A pair of scissors
A 3 volt lithium battery (CR2032)
Electrical (or other) tape
An LED
About 1 inch plastic piece
You need:
A pair of scissors
An LED
Step 1: Step One
First off, insert the battery into the two pins of the LED.
Positive is the longer one and negative the shorter one.
What is seen on the image should happen.
Step 2: Step Two
Insert the plastic piece between the anode (longer pin) and battery.
It will create a division, so, pressing on the two pins should make the LED light up.
Step 3: Final Step
Cut a piece of tape and wrap it around the assembly.
You just made a quick emergency LED Switchie!
