Introduction: My Pencil Case
Hello, My name is Thomas, I am 13 years old, I am passionate about manual work and this is my first instructable!
Here's how I made a pencil case for my favorite markers. Everyone can adapt the size of the model according to their specific uses.
Step 1: I Make the Canvas
I cut a first length of adhesive of about 20 cm that I place on my work surface, adhesive side up.
I then cut 5 strips of 25cm that I position perpendicular to the first strip, covering about 1cm on this first strip; overlapping the strips between them by 5 mm.
I then cover the set with 6 strips of 25cm that I glue perpendicular to the previous strips, overlapping them by 5mm
Step 2: I Cut the Canvas
I draw a square of 20cm side, and I cut this square with a cutter or non-stick scissors
Step 3: Decorating the Pencil Case
I fold the square in half
I make the decoration of my pencil case
I chose to paste a decoration that I made with my Cricut. It's easier to do it at this stage because I can glue it flat and therefore make my pattern stick well.
I line the two longitudinal sides of the square with black electrician's tape.
Step 4: Assembling the Zipper
I glue the first edge of the pencil case to the first edge of the zipper with the glue gun.
I glue the second edge of the pencil case to the second edge of the zipper with the heat gun.
Step 5: Finishing
I close the kit by sticking a 10cm piece of Gray Tape and a 5cm piece of electrician's tape at both ends.
I cut off the excess pieces with scissors. And There you go !
