Introduction: My Third Project: Smart Tank Chassis
This new toy is just arrived~ It is a smart tank chassis with L9110 on both side. After reading the datasheet and try to understand it with my very limited knowledge, it is a motor driver chip that can control the rotation direction of a motor directly. That means I can play it without using an additional motor shield because it's just embedded in the tank! : D A board is also included in this tank and this makes the project simpler. : )
Step 1: Parts
Step 2: First Wiring and Testing
I connect IA on the left side to Arduino pin 8 and VCC to + of the battery box. GND is wired to both - of the battery box and Arduino GND. Download the code in elab peers and test it... It moves forward. After that I test IB and it moves backward. I test it again on the other sides and figure out how to control the direction as follow:
Forward: IA on the left side and IB on the right side
Backward: IB on the left side and IA on the right side
Turn left: IB on the left side and IB on the right side
Turn right: IA on the left side and IA on the right side
Step 3: Second Wiring and Code
I do the wiring again as follow:
IB on the right side > pin 8
IA on the left side > pin 9
IA on the right side > pin 10
IB on the left side > pin 11
Write the simple code that instructs the tanks moving forward, backward, turn left and then turn right for 10 seconds each and then loop again:
int motorPin = 8;
//right side to IB - forwardint motorPin2 = 9; //left side to IA - forward
int motorPin3 = 10; //right side to IA - backward
int motorPin4 = 11; //left side to IB - backward
void setup() {
Serial.begin (9600);
pinMode(motorPin, OUTPUT);
pinMode(motorPin2, OUTPUT);
pinMode(motorPin3, OUTPUT);
pinMode(motorPin4, OUTPUT);
void forward(){
digitalWrite(motorPin, HIGH);
digitalWrite(motorPin2, HIGH);
digitalWrite(motorPin3, LOW);
digitalWrite(motorPin4, LOW);
void backward() {
digitalWrite(motorPin, LOW);
digitalWrite(motorPin2, LOW);
digitalWrite(motorPin3, HIGH);
digitalWrite(motorPin4, HIGH);
void turnLeft() {
void turnRight() {
void loop () {
forward();
delay(10000);
backward();
delay(10000);
turnLeft();
delay(10000);
turnRight();
delay(10000);
Yeah! It moves in the same way! I think I can start adding different modules and let it do more job. Thanks for watching again. See you.
