My First Woodturning Project(s)
Intro: My First Woodturning Project(s)
So I took this weekend woodturning class at The Crucible in West Oakland, and here's what I made. This is actually my very first woodworking project ever. Needless to say, I'm quite happy with the results.
(The Crucible is a really cool place, by the way - they do lots of classes for youth and adults, anything from paperworks, to stone carving and blacksmithing, with a big emphasis on anything fire-related. Check them out if you're in the Bay Area!)
Both of these bowls were tuned from very wet / freshly felled black acacia. The first day, I did all but the finishing on the smaller bowl, and roughed out the second, larger bowl (which was a bitch - with all those knots, it felt like I was holding a jackhammer at times!)
That also means that I was able to dry the smaller bowl overnight (and a bit more in the microwave in the morning), but I didn't get a chance to dry out the larger one before finishing it.
The smaller bowl, shown first, is 7" across, and wound up very thin: about 1/6" or so - thin enough that you can see a little light shining through that big knot at the bottom. Because we started with very wet wood, and the walls of the bowl are very thin, it developed quite a bit of warping while drying afterwards. You can see this really well on the first, side-on set of pictures, but it's actually not that noticeable in person.
The second bowl is 9" across, and about 1/3" thick. It was made out of a much more "ambitious" piece of black acacia, containing a big "crotch" (Y-shape, where a big branch splits off the main trunk of the tree). I decided to leave a bit of the natural bark exposed at the crotch, to accentuate that feature.
Because of time pressure (most other people in the class were only doing one bowl for the weekend), the more challenging nature of the wood, and lack of drying, there are a few more technical flaws with this piece, but overall, I do like it a lot.
There's a lovely convoluted knot at the bottom of the bowl - shown in a close-up at the end. The wood is actually carved and sanded perfectly flat there, but the folds in the grain make it look like a little maelstrom...
34 Comments
HPandLOTR 10 years ago
nice :)
sdbigguy 10 years ago
JamesRPatrick 14 years ago
pvhaak 15 years ago
canida 16 years ago
pc1949 16 years ago
darkmuskrat 16 years ago
MadMechanicMike 16 years ago
My wood projecs
Patrik 16 years ago
steadmanjon 16 years ago
Patrik 16 years ago
A lathe is great, because even as a beginner you can achieve some beautiful results relatively quickly. The drawback is that It would be a much bigger investment if you had to buy your own equipment - which is why it's nice to have access to a fully equipped workshop, like at the Crucible.
caitlinsdad 16 years ago
Patrik 16 years ago
I'm not happy with the lettering on the larger bowl, but I'm thinking I may want to redo the bottom of that one at some point anyway. I didn't have time to dry the wood properly in class, so I wasn't able to sand the bottom to my liking. The bottom is the wood closest to the bark, so it's very young and a bit spongy, making it really hard to sand when wet.
Hm... a little branding iron would make for a great instructable though!
awoodcarver 16 years ago
Patrik 16 years ago
Yep, that's more or less what we did - well, on the smaller bowl anyway. I roughed it out to a bit under 1/2 inch on the first day, then took it home to dry overnight. Next day, I put it in the microwave a couple of times to dry further, and finished it.
The microwave trick was suggested by our teacher, Joey Gottbrath: just nuke your roughed-out piece on high for 30 seconds at a time. It heats the wood very evenly, and it's amazing how much sap just sweats out of the wood. If you nuke it too long at a time, the wood may crack explosively - that's why you only do 30 seconds at a time. Plus if it does crack at this point, at least you haven't invested too much time and effort into it yet, I guess. Joey mentioned that he had seen even some master wood turners use this trick, if they were too impatient to let their roughs sit on a shelf for weeks or months...
For the larger piece, I only had time to rough out the outside of the bowl the first day, so we left it on the lathe wrapped in a plastic bag overnight, and I finished everything while the wood was still wet the next day. Not ideal, and it shows in the sanding in places.
killerjackalope 16 years ago
Patrik 16 years ago
Patrik 16 years ago
