Introduction: My Home Made Solar Cell Step by Step
with materials from the hardware store.
This cell is made from cuprous oxide instead of silicon and you can build a working solar cell in 2 hours
to build it i follow this instruction: http://scitoys.com/scitoys/scitoys/echem/echem2.html
on
Step 1: Materials You Will Need
A sheet of copper flashing from the hardware store
A transparent CD case
Electric wire
Sodium bicarbonate or Table salt
An electric stove
hot glue
solder
Sheet metal shears for cutting the copper sheet
I suggest you visit http://scitoys.com there are many projects and interesting kit
Step 2: How to Prepare Copper
The first step is to cut a piece of the copper sheeting that is about the size of the burner on the stove. Wash your hands so they don't have any grease or oil on them. Then wash the copper sheet with soap or cleanser to get any oil or grease off of it. Use the sandpaper or wire brush to thoroughly clean the copper sheeting, so that any sulphide or other light corrosion is removed.
Next, place the cleaned and dried copper sheet on the burner and turn the burner to its highest setting.
Step 3: Cooking the Copper
cook the copper for at least 30 min.
As the copper gets hotter, the colors are replaced with a black coating of cupric oxide. This is not the oxide we want, but it will flake off later, showing the reds, oranges, pinks, and purples of the cuprous oxide layer underneath.
The last bits of color disappear as the burner starts to glow red.
When the burner is glowing red-hot, the sheet of copper will be coated with a black cupric oxide coat. Let it cook for a half an hour, so the black coating will be thick. This is important, since a thick coating will flake off nicely, while a thin coat will stay stuck to the copper.
After the half hour of cooking, turn off the burner. Leave the hot copper on the burner to cool slowly. If you cool it too quickly, the black oxide will stay stuck to the copper.
Step 4: Prepare the Cooked Copper
When the copper has cooled to room temperature (this takes about 20 minutes), most of the black oxide will be gone. A light scrubbing with your hands under running water will remove most of the small bits. Resist the temptation to remove all of the black spots by hard scrubbing or by flexing the soft copper. This might damage the delicate red cuprous oxide layer we need to make to solar cell work.
When you are finished cleaning the copper should be as in the photo
Step 5: Assemble the Cell
Cut another sheet of copper ,
Solder a wire to each copper plate
glue to insulate the soldering
glue the plate as in photo
Step 6: Fill and Seal the Cell
seal the cell and fill it with a solution of baking soda (or cooking salt) and water
Step 7: Test the Cell
test the cell whit Sunlight
A note about power
my cell produces 58 microamps at 0.10 volts.
Don't expect to light light bulbs or charge batteries with this device. It can be used as a light detector or light meter, but it would take acres of them to power your house.
Finalist in the
Earthjustice United States of Efficiency Contest
6 People Made This Project!
- Newphysicist_com made it!
- kalpesh.dhalwalkar.7 made it!
See 2 More
218 Comments
5 years ago
you spelled with wrong at the bottom of the page
5 years ago
what can I power with it to show people during a science fair project
12 years ago on Step 7
sir can i make many of this solar panel and then connect them to each other like a battery? ,, and if i can how many of this solar panel should i make for me to be able to power a small light bulb used for toys?
Reply 7 years ago
You need 22 cells to light a small toy bulb connect all cells in series
Reply 5 years ago
Reply 7 years ago on Step 7
I BELIEVE I CAN HELP YOU A BIT, SOLAR CELLS ALL ARE .1/2 VOLT, THE SIZE OF THE CELL DETERMINES THE AMPERAGE. LETS SAY YOU WANT TO BUILD A 12V SOLAR PANEL CHARGER, YOU WILL NEED 27 CELLS WHICH WOULD EQUAL ABOUT 13.5 VOLTS, YOU NEED 1 VOLT AND A HALF MORE TO CHARGE. I BUILT ONE MANY YEARS AGO HOOKED IT UP TO A BOOM BOX AND IT PLAYED AS IF IT HAD BATTERIES, ONLY SUNLIGHT WAS USED. SHOULD YOU BUILD ONE USE SILICONE ADHESIVE ON THE CELLS.
GOOD LUCK
5 years ago
I made it myself. Just go to Inplix webpage if you'd like do the same
7 years ago on Introduction
Hi just wondering which piece of copper acts as the anode and which the cathode, and why is the saltwater needed? what is its function.
Reply 7 years ago
This is NOT how normal solar cells work, this device is based upon both the sunlight, and, the chemical reaction that a battery uses since there is an electrolyte added to the flow between the plates, which is exactly how a battery works, not a solar cell. Salt water or sodium bicarbonate and water create an acidified electrolyte that makes the water more conductive and it allows the electrons to flow through the water between the plates like a battery does, not a solar cell.. Solar cells are dry and do not have an aqueous solution in them, however, they operate by making a voltage with a combination of photons from light . The photons flow through the conductive glass plate to the next layer which is titanium dioxide, which then the photons excite the titanium dioxide and force an electron to be released from the titanium dioxide molecule, transferring the electon to the conductive glass to the electrode (wiring) creating a current flow to do work. The current flows from the titanium dioxide layer through the conductive layer of the glass and flows to the load, where the work is done, then, it flows back to the other side of the glass (the bottom layer), through the conductive layer where it returns back to the cell into a catalyst layer (middle layer) which is a type of electrolyte, and, it interacts with what's called the Tri-iodide molecule where the electron attaches itself to change the molecular structure to an iodide ion, where it is attracted to the titanium dioxide or "die molecule", reattaching itself back to it's original die molecule's inactivated state, waiting for another photon to react with the "die" molecule to excite it and start the process of electron flow all over again. By the way, the cell made here in this instructable does react with photons to release an electron, however, when the electron flows, it starts one of two things, it starts a galvanic reaction where it has an anode and a cathode like the battery does. The copper and the oxide in the plate in this instructable have an oxidation preformed on one side which starts a (chemical) galvanic reaction at the anode, where additional oxidation occurs, it loses electrons and acts as the reducing agent for the cathode. The process is similar, however, it is a repeated action without the oxidation process happening in the solar cell, but, the process that this instructable has is both chemical and thermal, . The heat, chemical reaction, and similarity of metals in this instructable are actually cancelling out what normally creates the 4 volts per cell, from the dissimilarity of metals in the solar cell which creates the (difference in potential between the metals) because the oxides are not dissimilar enough as the acids in the electrolyte are making more and more oxides which are just more and more conductive, making the electron flow slow down because the electrolyte is becoming too conductive. This is a solar battery that is allowing the flow and chemical reaction to short out the plates, not giving enough energy to take the electron and bring it back as an inactivated state again, and only give enough by way of chemical action, however, the heat from the sun is only increasing the flow of electrons by increasing the molecule size, exciting it in one way, but, decreasing it's voltage output due to the similarity in metals instead of increasing by the dissimilarity of them. If the cell made here had maybe an aluminum cathode, or a graphite cathode, the system would most likely function much better, becoming much more active with the heat to make a much more reactive galvnic (battery charge output) however, photons don't seem to be functioning in this cell as in a real solar cell due to the fact that the copper reactions are NOT photon reactive like titanium dioxide and oppositely reactive when the current or electrons return to the copper plate, it's merely the heat and acid creating galvanic reaction, and, a minimal flow of electrons. Please do not put sparks or a flame next to one of these cells made from this instructable, it is bound to create obnoxious flammable or explosive gases, maybe even hydrogen which would not be nice if ignited.
Reply 6 years ago
good
Reply 6 years ago
size depends
small cathod
6 years ago
Can it turn a dc motor
6 years ago
sir i need to charge a cellphone using this can you explain to me how can i do it? please answer me
6 years ago
how much volts and wats we got from this cell?
6 years ago
how much cost sir?
7 years ago
a big cooper plate can make more voltage
Reply 7 years ago
What if i use an aluminum does it work
7 years ago
What if i use a aluminum sheet instead of a copper sheet
7 years ago
Just though it was interesting that by your numbers (58 microamps and 0.1 volts) you would need 1,000,000 cells (rounding down) to power one 60w light bulb, which is about 50,000 square meters (assuming 4x2 inches) as opposed to typical photovoltaics which using the same area would produce about 12,000,000 watts peak.
7 years ago
WHAT IS COPPER FLASHING? HOW THICK MUST IT BE? HOW LONG? HOW WIDE? i CANNOT UNDERSTAND THE DIAGRAM IN SPANISH WHICH INDICATES PRESUMABLY A NEGATIVE AND POSITIVE, NOT CAN I ESTABLISH THE PURPOSE OF THE SMALL STRIP OF COPPER. HELP ME, I'M TECHNICALLY AN IDIOT BUT DESPERATELY NEED TO BUILD THIS CELL.
