Introduction: Sathothy's Guide to Knex Ballmachine Elements/lifts
Welcome to my guide to my new knex ballmachine elements/lifts. In this guide you will find elements that are made by me(and some other elements that arent posted yet and awesome elements that are worth it to post it again).
I will keep editing this guide when i made an new element( witch hoppfully whil happen alot) So remember to check this guide now and then.
Also if you have any name ideas for elements please suggest them( I'm bad with names)
Step 1: Ball Shute Thingy
The ball rols in this element.
This element is like toeti's element in obligation, but since that element doesnt work whit the newer style balls i decided to make one that works whit the newer style balls.
This one is less costumizaible but you can make nice curves and twists whit it.
Step 2: Ball Lowerer
.This is an original element by bezempje95 but since he made all his video's private i decided to post it.
Be sure that the ball enters this element whit speed others it won't work.
I used it in my ballmachine fireblast(https://www.youtube.com/user/Sathothy?feature=mhee#p/u/12/cUAxFwb920I)
Step 3: Micro Knex Ferris Wheel
Its a micro knex ferris wheel!
Step 4: Micro Knex Mazes
Two mazes i made whit micro knex
Step 5: Two Ball Ball Arm
This element is originally designed by bezempje95 I only modifieded it. There are two versions of this a big one and a smaller one. The big one was used in armaggedon, and the small one was used in Composition
Step 6: Flip-flop Path Selector
This isen't an element and it isen't new but it's worth posting it.
I recommend this path selector if you have lots of pieces becuease you don't need lots of hight for it but you do need lots of pieces(mainly snowflakes)
Step 7: Ball Arms
I used the motorcycle ball arm in armageddon
Step 8: Two Rail Coaster Path
Its a new way of crostie path. This way there isen't much friction and it goes smooth.
I used this element in armageddon
Step 9: Sort of Pinwheel Thingy
It looks a bit like the pinwheel
Step 10: Crostie Stairs
Step 11: The Ball Replacer
This is the ball replacer as used in my ballmachine Nebulus( https://www.instructables.com/id/Knex-ballmachine-Nebulus/ )
Step 12: S-drop
A cool element that uses micro track. I used this in Composition.
Step 13: Micro Pathing
A cool type of micro path, you can use this with all types of different lengths of rods to create cool curves. I used this in Composition.
Step 14: Down and Up Ball Arm.
The ball enters the upper slot, goes down, rolls out of the upper slot, rolls into the other slots and then it gets raised up again. I used this in Composition
Step 15: Spinning Shute
The ball enters the shut from above and then it starts spinning. It makes a really cool sound aswell. I used this in Composition.
Step 16: Motorized Path Radomizer
This is the motorized path randomizer I used on Composition.
Step 17: Path Selector
Basicly just my spin on some of the other designs like this. I used it on Composition.
Step 18: Lifts
We are heading to the lifts right now, which I invented on my own.
Step 19: Micro Knex Wheel Lift
You should be able to make this out of the pictures.
It are 15 cabines
Step 20: Motorized Madness Ballmachine Lift
I made instructions for this lift right here: https://www.instructables.com/id/Knex-ballmachine-motorized-madness-circle-lift/
Step 21: Double Car Elevator Lift
This is the double car elevator lift I used on Composition. I have no idea how to explain it in words but I have a video of it here( the double car lift is shown near the end of the video):
Step 22: Shifting Wheel Lift
This is the shifting wheel lift I used on Composition, I made instructions for it here: https://www.instructables.com/id/Knex-shifting-wheel-lift-Instructions/
Step 23: The End
I hope that you enjoyed that serie of elements!
If you have any questions, ask them.
And don't forget to check this now and then for edits
And don't forget to comment, rate and subscribe!
