Introduction: NES Belt - DIY Version
This is the DIY version of the NES Controller Belt buckle. Its very easy to do and looks really awesome when its done.
Step 1: Materials
1. NES Controller
2. Scissors
3. Liquid Nails
4. 2 90degree Metal Corner Brackets
5. 1 1" screw
6. Plyers
7. Metal Hanger
8. Hammer
9. Soldering Iron and Solder
10. Belt buckle compatible belt.
2. Scissors
3. Liquid Nails
5. 1 1" screw
6. Plyers
7. Metal Hanger
8. Hammer
Step 2: Remove Cord From NES Controller
Take a screwdriver and open up the NES Controller.
Use scissors to cut the cord out of it from where it connects to circuit board.
Step 3: Cut the Bottom Section Off of the Hanger
Take plyers and make it look like this, by cutting off the bottom section.
Step 4: Use Plyers to Bend the Cut Section Into a Square
Bend it like this. Make one side smaller if needed to fit belt right.
Make it on average 1 1/2" On each side, but belts are different. Make it fit yours.
Step 5: Use Soldering Iron and Solder to Make the Ends of the Wire Connected.
Make sure you precariously perch your soldering iron to provoke misfortune. But on the other hand.. use the solder on an acceptable heat, and just hold the wire and solder the ends. Use gloves if needed, metal gets very hot.
Step 6: Find a Screw About 1 Inch Long.
Find a screw about 1 inch long.. who woulda though.
Step 7: Use Drill to Drill Hole and Insert Screw.
Use a drill to drill a hole the size of the screw. Take a pair of plyers and break off the head of the screw and then thread it into the hole using the plyers.
Step 8: Get 2 Corner Brackets (90 Degree Pieces of Metal With a Screw/bolt Hole on Each Side).
Get 2 brackets. Take a hammer and flatten these down to make the space in the middle where it was bent at originally thick enough to fit the wire in.
Step 9: Put the 2 Flattened Brackets on the NES With the Wire Underneathe
Put the 2 flattened brackets on the NES with the wire underneathe, and put Liquid Nail underneath it to keep it there, as screws don't grab well in the circuit boards and stuff inside.
Step 10: Wait for It to Dry.
Chill around.. listen to some great tunes.
PLAYLIST OF CHOICE:
1. Senses Fail
2. Underoath
3. Rammstein
4. The Pillows
5. Rise Against
Yeah.. jam out dawg. You earned it.
PLAYLIST OF CHOICE:
1. Senses Fail
2. Underoath
3. Rammstein
4. The Pillows
5. Rise Against
Step 11: Try It on and Look Hott.
Walk around the town, and have a good time. Have fun with your new...
NES Controller DIY EDITION!! WOOOO!
