Introduction: NES Zapper LED Mod
About: Prop maker from the PNW.
How to modify a reproduction NES zapper with LED diodes. Great prop for a costume. A similar approach could be applied to other toy pistols.
Safety Gear:
respirator
safety glasses
Tools:
small pillilps screwdriver
soldering iron
wire cutter/strippers
small flat file
lighter
Materials:
NES Zapper
solder
scrap wire
momentary switch
x3 blue 3-3.2V LEDs
heat shrink/electrical tape
21/23 12V battery
21/23 battery harness
3D Print File for LED backet
Step 1: Disassemble
Start by removing the small screws and place them in a safe spot. Pry the halves apart, set aside the outer cover as well as the pistol's left side. Remove the clear lens and don't lose it. Cut the wires attached the to reverse momentary switch. Gut the wiring, LED/chipboard, and the cord. Use wire cutters to release the switch from the plastic pegs. Snip the leads off the switch and pull out the small plastic innards until all you have left is a single piece the resembles the letter L.
Step 2: Electronics
Use the small flat file to shave down the orange pegs. Slide the new momentary switch on the right peg. You want it to be snug. Next, place the plastic L piece on the left peg. Once aligned, the trigger should engage the L into the switch. If you have access to a 3D printer, download the provided file and print a bracket for the LEDs. Following the circuit diagram (*you will be using a different switch and battery than shown*). Twist the three LEDs together once in the bracket or wrapped together with electrical tape. Solder the battery harness to the switch, then tie in the LED cluster. You may need more length on the battery harness to reach the LEDs, there is plenty of extra wire scrap from gutting the pistol. Place all of the wiring with the half of the pistol. You may want to pad the battery harness to it doesn't slide around inside.
Step 3: Paint
Using Rust-oleum 2X satin stone gray spray paint, coat the two halves of the outer shell. Make sure the weather is warm with little to no humidity when painting. For better results, break the session three coats, with 5-10 minutes between coats. This paint is designed to bond with plastic but you may want to give it a clear coat for better resilience to chipping.
Step 4: Assembly
Making sure to keep the wire within the housing of the pistol, place the two halves back together. Then the outer shell halves. Pull the trigger to test the wiring, if everything is still working, secure the halves with screws.
