NEST Your Old Thermostat
Intro: NEST Your Old Thermostat
The heating system in my house is probably as old as the house itself. It’s about 30 years old, which is fine in terms of house years, but pretty much stuck in the ice-age as far as the technology is concerned. There are 2 main problems with commercial solutions:
- prohibitive pricing
- product as service
We all remember what happened to Revolv and I'm not too keen on having this happen to me in the middle of the winter. With that in mind, I present you with incredibly suspicious looking but functional NEST-Alike controller for your old thermostat. Don't worry, I'm planning on a much better enclosure to be added soon!
Features:
- ability to use an existing thermostat (in case wife moans about it)
- remote access
- AWAY mode
- optimal temperature indicator
- Works with Alexa
Soon (check here for updates )
- Google Home
- Google Calendar
- Multiple Sensors
- Radiator controls
- IFTT integrations
- Tasker support
- HTTP Requests
- A much better looking enclosure
STEP 1: How a Thermostat Works
The thermostat is likely connected to the HIGH VOLTAGE! Do not attempt to do anything unless you made sure the circuit is off. You can harm yourself and cause damage to the connected equipment. Consider consulting a qualified electrician to assure your safety.
The Honeywell thermostat is a wall mounted unit, powered by the mains (Sonoff basics need min 90V, my circuit has 230V). The box is connected to the main controlling unit (which is a more advanced box) and it sends the signal when the temperature drops below the target level. While your unit may be different, the principle is most likely the same. If you have 3 wires and no radio connection between the wall-mounted unit – this is the tutorial for you.
I know how the 3-wire thermostats work in a principle, which didn’t stop me from blowing a fuse by shorting 2 wires by accident! I have 3 wires connected to the unit (with 4th being the earth). My Honeywell thermostat is not wireless, so to switch the signal, I can use Sonoff Basic. It’s time to take it apart and see how the signal is sent to the unit.
Upon closer inspection, the terminal is connected in the following way:
- (blue) – Ground
- (yellow) – signal, when pulled high the heating is on
- not in use
- (red) – the live wire used to pull the signal high
To achieve my goal, I have to short the live wire with the signal wire when I want my heating to be turned on. If you have a similarly connected thermostat, you are in luck as Sonoff Basic will be enough to do the trick.
STEP 2: Getting Sonoff Basic Ready
Before we start connecting the wires, we have to add a temperature sensor (DHT11) to the mix. Make sure you have Tasmota firmware flashed to your Sonoff device (I have an excellent flashing guide here) and your Tasmota-enabled Sonoff is configured correctly (also already covered by me). Now, all you have left is to connect the DHT11 sensor to the Sonoff and configure it for temperature reporting.
DHT11 comes with 3 pins wired:
Signal - GPIO14
Vcc - 3.3V
GND - GND
I poked a hole through, I’m not bothered with how it looks like now, all I need is the proof of concept and the validation. I will make a nice and shiny enclosure once my 3D printer arrives. I paid extra attention to how I wire the Sonoff, as I have to make sure that the live wire connects to the signal wire on the other end of the Sonoff device. The Honeywell unit has the load resistor (R) built inside which limits the current. While the circuit is protected by the 3A fuse, It’s smart to match the same resistance for extra protection. Once I had the wires ready, it was time to flip the main power off and wire the Sonoff back.
Sonoff Tasmota - Honeywell thermostat
INPUT Live - 4th terminal Live
INPUT GND - 1st terminal GND
OUTPUT Signal - 2nd terminal Signal
I mentioned before that for now, I’m not going to stress about the looks of this. The wife has been convinced and I can focus on the functionality and clearing any bugs that will happen. The good thing is that the original thermostat is still working. If I turn it up, it will override the Sonoff Tasmota based one. This should be a great backup for any unexpected events.
STEP 3: NodeRED
I came across this design online. It looks great, however upon close inspection, the widget isn’t really suited for NodeRED. It needs 5 payloads to be set, which is just not how node alike design works. It took me some time to figure out the best way of passing all that information over to update the widget and keep it functional. I’m sure with time I’ll spend more time on the design so I could push all the needed updates with a single msg object. For now, it is what it is.
Temperature stream
DHT11 reports every X seconds back to the NodeRED server. I increased this frequency through the Tasmota’s console. Just run the command to set the frequency in sec:
TelePeriod Set telemetry period between 10 and 3600 seconds
This is done mostly for tests, as I don’t want to wait for minutes to see if my bug fixes worked. Keeping frequency high will cause the heating to fire more frequently for shorter periods of time, so refrain from setting it to 10 sec for other than testing purposes. The MQTT node pulls the data from:
sonoff/tele/SENSOR
and keeps the most useful data in the following objects:
msg.payload.DHT11.Temperature<br> msg.payload.DHT11.Humidity
To limit the errors, I added the smooth node to average the results and updated the flow variable: NodeRED:
Function Node - Update the 'TempAmbient'
flow.set('TempAmbient', msg.payload.DHT11.Temperature);<br>return msg;Widget update
I decided that 5 seconds is a good refresh rate, therefore I’m pushing all needed values with this frequency. The only exception is the slider, which for obvious reason responds instantly.
Each corresponding node sends the payload with the assigned topic to the nest-alike widget.
- colour (heating|cooling*|off & hvac_state)
- leaf (true|false & has_leaf)
- away (true|false & away)
- Ambient temp (number & ambient_temperature)
- Target temp (number & target_temperature)
*not in use
NodeRED: Function Node - Widget Update
colour
<p>x = flow.get('TempTarget'); //target<br>z = flow.get('TempAmbient'); //ambient</p><p>if (z < x){ flow.set('heatingState', "heating"); flow.set('heatingSwitch', "ON"); } if (z >= x){ flow.set('heatingState', "off"); flow.set('heatingSwitch', "OFF"); } msg.payload = z; msg.topic = "ambient_temperature"; return msg;</p>
leaf
<p>x = flow.get('TempAmbient');<br> if (x > 17 && x < 23){ flow.set('leaf', true); msg.payload = true; msg.topic = "has_leaf"; return msg; } else{flow.set('leaf', false); msg.payload = false; msg.topic = "has_leaf"; return msg; }</p>
Colour away override
<p>x = flow.get('away');<br> if (x === true){ msg.topic = "hvac_state"; msg.payload = "off"; return msg; }</p><p>msg.topic = "hvac_state"; msg.payload = flow.get('heatingState');</p><p>return msg;</p>
Away
<p>x = flow.get('away');<br> if (x === true){ flow.set('heatingSwitch', "OFF"); flow.set('heatingState', "off"); }</p><p>msg.topic = "away"; msg.payload = flow.get('away'); return msg;</p>
Target Temp
<p>if (msg.topic === "update"){<br> msg.topic = "target_temperature"; msg.payload = flow.get('TempTarget'); return msg; }</p><p>if (msg.command === "SetTargetTemperatureRequest") { flow.set('away', false); msg.topic = "target_temperature"; flow.set('TempTarget', msg.payload); }</p><p>if (msg.topic === "slider") { flow.set('away', false); msg.topic = "target_temperature"; flow.set('TempTarget', msg.payload); }</p><p>if (msg.command === "GetTemperatureReadingRequest"){}</p><p>return msg;</p>
As you see, I opted out for the flow variables, so I could recall the value at any given time. I have a debug flow which basically reads all stored values.
- ‘TempAmbinet‘ – stores the current temp
- ‘TempTarget‘ – holds the temp target value
- ‘leaf‘ – displays leaf if needed
- ‘away‘ – displays away status if needed
- ‘heatingState‘ – changes colour of the display
- ‘heatingSwitch‘ – controls the state of the relay.
The challenge was to actually make sure that the information is updated on “update” and when requested via other means (Alexa, etc). This is why you will see different conditions in the JavaScript. Each time the values are updated, sent to the flow variable and the widget is refreshed.
SliderTesting revealed that an additional slider update (slider pushes the target temperature) is needed. Slider sends the payload (number) with the associated topic “slider) when it’s moved. On top of this, I want the slider to get into the correct position if multiple web interfaces are in place. To do this, every 5 sec I simply update the slider position to a current target temperature.
NodeRED: Function Node - Update slider'
<p>msg.payload = flow.get('TempTarget');<br>return msg;</p>
The relay controller is simple, it takes (for now) two inputs. Alexa’s true|false and the interaction that follows an update to the “heating Switch” flow variable. There is no need for an instant action, so for the simplicity, it runs on the same 5sec update frequency as the rest of the flow.
The relay is connected via MQTT. Node is posting ON|OFF commands to the topic:
sonoff/cmnd/POWER1
The function node accepts the true|false from Alexa and also changes the state of the input according to the ‘heatingSwitch’ flow variable.
NodeRED: Function Node - Control Relay'
<p>if (msg.command === "TurnOffRequest"){<br> msg.payload = "OFF"; return msg; }</p><p>if (msg.command === "TurnOnRequest"){ msg.payload = "ON"; flow.set('TempTarget', 21); return msg; } if (msg.topic === "update"){ msg.payload = flow.get('heatingSwitch'); } return msg;</p>
This is the first device I had to turn the “auto acknowledge” off. Instead of automatically assuming a response I have generated one as I want the ability to query the set temperature. In principle, msg.payload = true|false indicates if the request has been successful, and the templates found here do the rest. If you are new to Alexa and NodeRed, be sure to read this.
I decided to pass the acknowledgements separate (I know this is not the best way) to be able to control it all a little bit better. Properly each response should be given at the end of the command chain. Mine is risking not returning errors should these happen. Note, that to be consistent, I only update the variables, while the refresh loop, pushes the new values over to the widget.
NodeRED: Function Node - Process Alexa Responses'
<p>// What is the thermostat's target temperature<br>if (msg.command === "GetTemperatureReadingRequest"){ x =flow.get('TempTarget'); msg.extra = { "temperatureReading": { "value": x}, "applianceResponseTimestamp": new Date().toISOString()}; msg.payload = true; return msg; } // Set the temperature to (not lower than 10 or more than 30) if (msg.command === "SetTargetTemperatureRequest"){ if (msg.payload < 10 || msg.payload > 30) { var range = { min: 10.0, max: 30.0 } msg.payload = false; msg.extra = range; } else { msg.extra = { targetTemperature: { value: msg.payload } }; msg.payload = true; } return msg; } // Turn it on if (msg.command === "TurnOnRequest"){ msg.payload = true; flow.set('away', false); flow.set('TempTarget', 21); return msg; } // Turn it off if (msg.command === "TurnOffRequest"){ msg.payload = true; flow.set('away', true); return msg;</p>
STEP 4: Conclusion
If you expose the NodeRED dashboard to WAN the entire heating system can be controlled remotely. I'd recommend you to read the following articles to get up to speed with NodeRED and NodeRED security.
In addition, if you want to get informed about the updates to this project - consider following me on the platform of your choice:
And if you feeling like buying me a coffee or supporting me in a more continuous way:
I hope you have enjoyed the project!
6 Comments
ed.darby 5 years ago
notenoughtech 5 years ago
https://youtu.be/brDpUdJ6A_0
mosix 5 years ago
good job, but I suggest you use the DHT22 to get a tenth grade accuracy, and do not connect it directly on the sonoff because you would have a wrong reading due to internal warming
Side note. I'm working on a support for multiple temp sensors
