Introduction: NODE MCU ESP12E V2 and 3x DS18B20 Sensors Send Data to HomeAssistant
About: I'm a handyman, and I like all technical toys
ESP with DS18b20 data logger.
Step 1: Material
  • NODE MCU ESP12-F (or something like that)
  • DS18B20 sensors (how much do you need?, I have 3pcs.)
  • resistor 4k7
  • microUSB to USB cable, PC, USB 5V charger
  • ArduinoIDE
...and a little patience and skill :)
Step 2: Wiring
  • the resistor (4k7) is connected between red and yellow cables
  • yellow data cable is connected to D2 (pin)
  • red is for 3.3V
  • black is GND
Step 3: Code
This is the code that is compiled according to the needs of my project. I drew from official sources but also from other similar projects. Please note, this may not be 100% suitable for everyone.
#include <ESP8266WiFi.h>
#include <PubSubClient.h>
#include <OneWire.h>
#include <DallasTemperature.h>
#define ONE_WIRE_BUS 2
#define TEMPERATURE_PRECISION 9
#define wifi_ssid "your wifi"
#define wifi_password "youf wifi pass"
#define mqtt_server "IP MQTT server"
#define mqtt_user "MQTT user"
#define mqtt_password "MQTT pass"
#define temperature_topic1 "sensor/temperature1"
#define temperature_topic2 "sensor/temperature2"
#define temperature_topic3 "sensor/temperature3"
OneWire oneWire(ONE_WIRE_BUS);
DallasTemperature sensors(&oneWire);
//address to DS18B20 sensors
DeviceAddress Sensor1 = { 0x28, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00 };
DeviceAddress Sensor2   = { 0x28, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00 };
DeviceAddress Sensor3   = { 0x28, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00 };
WiFiClient espClient;
PubSubClient client(espClient);
void setup() {
  Serial.begin(115200);
  delay(10);
  sensors.begin();
  setup_wifi();
  client.setServer(mqtt_server, 1883);
  Serial.println();
  Serial.println();
  Serial.print("Locating DS18B20 sensors...");
  Serial.print("I found ");
  Serial.print(sensors.getDeviceCount(), DEC);
  Serial.println(" devices.");
  Serial.print("Parasite power is: ");
  if (sensors.isParasitePowerMode()) Serial.println("ON");
  else Serial.println("OFF");
  if (!sensors.getAddress(Sensor1, 0)) Serial.println("Unable to find Sensor 1");
  if (!sensors.getAddress(Sensor2, 1)) Serial.println("Unable to find Sensor 2");
  if (!sensors.getAddress(Sensor3, 2)) Serial.println("Unable to find Sensor 3");
  sensors.setResolution(Sensor1, TEMPERATURE_PRECISION);
  sensors.setResolution(Sensor2, TEMPERATURE_PRECISION);
  sensors.setResolution(Sensor3, TEMPERATURE_PRECISION);
  Serial.print("Sensor 1 Adress = ");
  printAddress(Sensor1);
  Serial.print(" read temperature: ");
  Serial.print(sensors.getTempC(Sensor1));
  Serial.print(" ºC, Resolution: ");
  Serial.print(sensors.getResolution(Sensor1), DEC);
  Serial.println();
  Serial.print("Sensor 2 Adress = ");
  printAddress(Sensor2);
  Serial.print(sensors.getTempC(Sensor2));
  Serial.print(sensors.getResolution(Sensor2), DEC);
  Serial.println();
  Serial.print("Sensor 3 Adress = ");
  printAddress(Sensor3);
  Serial.print(sensors.getTempC(Sensor3));
  Serial.print(sensors.getResolution(Sensor3), DEC);
  Serial.println();
void printAddress(DeviceAddress deviceAddress)
  for (uint8_t i = 0; i < 8; i++)
    if (deviceAddress[i] < 16) Serial.print("0");
    Serial.print(deviceAddress[i], HEX);
void printTemperature(DeviceAddress deviceAddress)
 float tempC = sensors.getTempC(deviceAddress);
 if(tempC == DEVICE_DISCONNECTED_C)
    Serial.println("!!! Sensor is not connected !!!");
    return;
 Serial.print("Temp C: ");
 Serial.println(tempC);
void setup_wifi() {
  delay(10);
  Serial.println();
  Serial.print("Connecting to ");
  Serial.println(wifi_ssid);
  WiFi.begin(wifi_ssid, wifi_password);
  while (WiFi.status() != WL_CONNECTED) {
    delay(500);
    Serial.print(".");
  Serial.println("");
  Serial.println("WiFi connected");
  Serial.println("IP address: ");
  Serial.println(WiFi.localIP());
void reconnect() {
  // Loop until we're reconnected
  while (!client.connected()) {
    Serial.print("Establishing connection to MQTT server ...");
    if (client.connect("ESP8266Client", mqtt_user, mqtt_password)) {
      Serial.println("connected");
    } else {
      Serial.print("failed, rc=");
      Serial.print(client.state());
      Serial.println(" try again in 60 seconds");
      delay(60000);
void printData(DeviceAddress deviceAddress)
  printTemperature(deviceAddress);
bool checkBound(float newValue, float prevValue, float maxDiff) {
  return !isnan(newValue) &&
         (newValue < prevValue - maxDiff || newValue > prevValue + maxDiff);
long lastMsg = 0;
float temp1 = 0.0;
float temp2 = 0.0;
float temp3 = 0.0;
float diff = 0.1;
void loop() {
  if (!client.connected()) {
    reconnect();
  client.loop();
  delay(60000);
  sensors.requestTemperatures();
  Serial.println("********************************************************");
  Serial.println("Scaned temperature Sensor1:");
  printData(Sensor1);
  Serial.println("Scaned temperature Sensor2:");
  printData(Sensor2);
  Serial.println("Scaned temperature Sensor3:");
  printData(Sensor3);
  long now = millis();
  if (now - lastMsg > 2000) {
    lastMsg = now;
  float newTemp1 = sensors.getTempC(Sensor1);
  float newTemp2 = sensors.getTempC(Sensor2);
  float newTemp3 = sensors.getTempC(Sensor3);
    if (checkBound(newTemp1, temp1, diff)) {
      temp1 = newTemp1;
      Serial.print("Send temperature Sensor1: ");
      Serial.println(String(temp1).c_str());
      client.publish(temperature_topic1, String(temp1).c_str(), true);
    if (checkBound(newTemp2, temp2, diff)) {
      temp2 = newTemp2;
      Serial.print("Send temperature Sensor2: ");
      Serial.println(String(temp2).c_str());
      client.publish(temperature_topic2, String(temp2).c_str(), true);
    if (checkBound(newTemp3, temp3, diff)) {
      temp3 = newTemp3;
      Serial.print("Send temperature Sensor3: ");
      Serial.println(String(temp3).c_str());
      client.publish(temperature_topic3, String(temp3).c_str(), true);
Step 4: HA Setup
  1. install MQTT broker for HA, for example https://learn.adafruit.com/set-up-home-assistant-...
  2. configure MQTT broker, paste to config this for three sensors:
mqtt:
  broker: *ip address MQTT server"
  username: *user*
  password: *pass*
sensor 1:
  platform: mqtt
  state_topic: "sensor/temperature1"
  qos: 0
  unit_of_measurement: "ºC"
sensor 2:
  platform: mqtt
  state_topic: "sensor/temperature2"
  qos: 0
sensor 3:
  platform: mqtt
  state_topic: "sensor/temperature3"
  qos: 0
Step 5: Finish
Maybe you will:
good luck :)
